High Idle V-10 - Ford Truck Enthusiasts Forums
Modular V10 (6.8l) SPONSORED BY:
High Idle V-10
Old 03-14-2011, 02:59 PM
EMC V10 X's Avatar
EMC V10 X EMC V10 X is offline
EMC V10 X is starting off with a positive reputation.
High Idle V-10
I have an 01 Excusion with a V-10. I have been chaseing a high idle issue for a while now. Warm idle in gear is about 850 rpm in gear and 1000 rpm in neutral. I dont think it is the IAC valve. I removed and cleaned it and there was absolutly no change. It moved quite freely and worked properly. The idle is also very consitent. No flucuations and the idle is very smooth.
How about a brain storm of all the causes for a high idle and this weekend I will check all of the ideas until I find the solution. (starting with the cheapest of course!). Thank you for all for the sugestions!
Old 03-15-2011, 08:49 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Is your tach gauge off ?
what does it show when the key is on, but the engine is not running?
Also, a vacuum leak can do that. Or, someone cranked down on the idle stop on the throttle body.
Old 03-15-2011, 06:21 PM
barthel's Avatar
barthel barthel is offline
barthel has a good reputation on FTE.barthel has a good reputation on FTE.
I asked the same question a week ago or so, and was told that's somewhat normal for a V10. Mine runs up to about 1700 on start up, hovers about 1200 but settles down to about 800 or so when it gets going.
Old 04-07-2011, 09:18 AM
EMC V10 X's Avatar
Mine stays up at about 1000 even fully warmed up.
Old 04-07-2011, 06:06 PM
LSchicago2's Avatar
LSchicago2 LSchicago2 is offline
LSchicago2 has a great reputation on FTE.LSchicago2 has a great reputation on FTE.LSchicago2 has a great reputation on FTE.LSchicago2 has a great reputation on FTE.LSchicago2 has a great reputation on FTE.
My 2011 idles at 600 rpm.
Old 04-07-2011, 10:54 PM
twigsV10's Avatar
twigsV10 twigsV10 is offline
twigsV10 is a splendid one to beholdtwigsV10 is a splendid one to beholdtwigsV10 is a splendid one to beholdtwigsV10 is a splendid one to beholdtwigsV10 is a splendid one to beholdtwigsV10 is a splendid one to behold
Dad's f250 v10 idels a 1000 slows down sum in D and dosen't seem to bother shifting into gear or driving, haven't found any thing wrong.
Old 04-08-2011, 12:14 AM
jh818's Avatar
jh818 jh818 is offline
jh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputation
Mine when it is warmed up idles around 665-667 while in D. Sometimes it's at the number of the beast.
Old 04-08-2011, 01:06 AM
trucktech trucktech is offline
trucktech is starting off with a positive reputation.
My 00 excursion idles around 1000 and 800 in gear I think it is high I am gonna start looking into this myself
Old 04-08-2011, 08:32 AM
Krewat's Avatar
Keep one thing in mind, the dash tach isn't exactly the most accurate...
If you have a scanner like the SCT X3, pull up the RPM pid.
Old 04-08-2011, 04:15 PM
bergy 2000 bergy 2000 is offline
bergy 2000 is gaining momentum as a positive member of FTE.
what rpm should you be running at idle? Most of my cars/trucks sit at or just below1000k in Pa.
Old 04-08-2011, 08:55 PM
wizardsr's Avatar
wizardsr wizardsr is offline
wizardsr is gaining momentum as a positive member of FTE.wizardsr is gaining momentum as a positive member of FTE.
The 2 valve V10's seem to idle a little high. My 2000 always idled high, but the 2005 (3 valve) that replaced it is a bit lower, idling around 600. My 2003 F350 V10 idles high as well, in the 800-1000 range. My 2003 F550 V10 idles higher than the 2005, but not nearly as high as the 03 F350 (yes, that's 3 V10's currently in the family ).
Old 04-08-2011, 10:18 PM
SKI-V10's Avatar
SKI-V10 SKI-V10 is offline
SKI-V10 is starting off with a positive reputation.
My 2008 idles at about 600 in gear when warmed up. I read this off my ScanGauge 11.
02 v10 warm idle? clawsd Modular V10 (6.8l) 3 03-20-2015 05:00 PM
Idle issue oneofakind97 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 03-12-2015 11:51 AM
Idle? EMC V10 X Modular V10 (6.8l) 10 12-31-2010 07:39 PM
V-10 Idle? EMC V10 X 1999 to 2016 Super Duty 0 11-20-2010 11:38 AM
88 F-250 High Fast Idle, High Idle Terry 1987 - 1996 F150 & Larger F-Series Trucks 5 10-03-1999 03:49 PM
Tags
1000, 2001, 2002, excursion, fast, ford, high, idel, idle, idles, neutral, rpm, start, truck, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
