Scan Gauges in stock
For anyone that wanted one from the group buy an missed out, or you just want one anyway, I now have several on hand that have Green digital face and match the OBS dash lights.
Let me know if your'e interested.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
1. INTAKE AIR 2- Intake Air Temperature taken at the throttle body inlet
2. COOLANT TEMP 2- Engine Coolant Temperature
3. RPM 2- engine Revolutions Per Minute
4. MANIFOLD PSI 1- Manifold Air Pressure (psia) for voltage based MAP sensors (mid 1990’s trucks).
5. Manifold PSI 2 – Manifold Air Pressure (psia) for frequency based MAP sensors
6. BOOST 1 – Boost Pressure in psig for voltage based MAP
7. BOOST 2 – Boost Pressure in psig for frequency based MAP
8. MILES PER HOUR 2- Miles Per Hour
9. TRANS TEMP 1- Transmission Temperature for 1998 and newer trucks
10. TRANS TEMP 2 – Trans temp derived from the trans temp sensor voltage for 1997 and older trucks.
11. TRANS VOLTS – Transmission temperature sensor raw voltage.
11. RUN TIME MINS- engine run time since last engine start. Can be used as a trip timer.
12. BATTERY VOLTAGE- Alternator/battery output voltage
13. PULSE WIDTH- injector pulse width in msec.
14. ENGINE OIL TEMP
15. EX. BACK PRESS – Exhaust back pressure
16. ICP DC – Injector Control Pressure Duty Cycle
17. ICP – Injector Control Pressure
18. INJ. TIMING – Injector Timing Deg BTDC
19. CURRENT GEAR – Current Transmission Gear
I'm sorry Jim... I didn't think before posting.
14. ENGINE OIL TEMP
14. ENGINE OIL TEMP
Received 5,149 Likes
on
1. * INTAKE AIR 2- Intake Air Temperature taken at the throttle body inlet
3. * RPM 2- engine Revolutions Per Minute
7. * BOOST 2 – Boost Pressure in psig for frequency based MAP
8. * MILES PER HOUR 2- Miles Per Hour
10. * TRANS TEMP 2 – Trans temp derived from the trans temp sensor voltage for 1997 and older trucks.
12. * BATTERY VOLTAGE- Alternator/battery output voltage
13. * PULSE WIDTH- injector pulse width in msec.
14. * ENGINE OIL TEMP
15. * EX. BACK PRESS – Exhaust back pressure
16. * ICP DC – Injector Control Pressure Duty Cycle
17. * ICP – Injector Control Pressure
19. * CURRENT GEAR – Current Transmission Gear
on
