Check Engine light reset? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-17-2014, 06:47 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Transmission Guides
Print Wikipost
Old 03-14-2011, 12:13 PM
nosebreaker nosebreaker is offline
nosebreaker is starting off with a positive reputation.
Is there some sort of reset to turn off the Check Engine light? I had replaced the TPS sensor, and after a day the engine seems to have stopped the high idle and returned to normal, and now it still has the check engine with the same error code, but the problem seems to be resolved. My previous post: http://www.ford-trucks.com/forums/10...ine-light.html
Old 03-14-2011, 12:31 PM
jh818's Avatar
jh818 jh818 is offline
jh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputation
Most code readers has an earase button to reset or turn off the CEL.
Old 03-14-2011, 12:44 PM
ol'yeller ol'yeller is offline
ol'yeller is gaining momentum as a positive member of FTE.
If you don't have a code reader, most parts houses will loan you one in their parking lot. It only takes a second to erase the codes and turn off the CEL as long as the problem(s) are fixed.
Old 03-14-2011, 12:51 PM
mwsF250 mwsF250 is offline
mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.
Most PCM software will self erase the code if the problem does not occur for a set number of operational cycles. Usually around 20 or 30. Not sure on these...
Old 03-14-2011, 02:00 PM
CodaMan's Avatar
CodaMan CodaMan is offline
CodaMan is starting off with a positive reputation.
Quote:
Originally Posted by ol'yeller View Post
If you don't have a code reader, most parts houses will loan you one in their parking lot...
Unless you live in California, but you can purchase one on Amazon for around $25.
Old 03-14-2011, 02:11 PM
jh818's Avatar
Quote:
They'll lend one to you in CA. You'll need to put down a deposit for the full cost of one. You get your deposit back when you return it.
I would just go and get one. Get a ScangaugeII. It has other gauges thay the dashboard doesn't offer. Plus, you can use it on other vehicles as well as long as it has the sensors for it.
Old 03-14-2011, 08:23 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Ya'all are making this way too hard!
The PCM's memory can be reset by either disconnecting the battery negative terminal or by removing the PCM's KAM fuse for 10 minutes if you don't want to reset your clock and radio settings.
Old 03-15-2011, 03:47 PM
That is correct in most cases - but it also erases your FI correction maps so your fuel economy will take a dip until it re-learns.
Old 03-15-2011, 06:06 PM
Quote:
Perhaps, but you are far better off starting from factory baseline programming after repairing a fault that has affected fuel trim and the resultant shifting parameters rather than trying to let the PCM re-learn and attempting to recover from skewed sensor data.
Old 03-15-2011, 06:35 PM
Good point. In the OP's case, he probably would be better off purging trims.
Old 10-25-2016, 06:46 PM
buckeyejake buckeyejake is offline
buckeyejake is starting off with a positive reputation.
Hi. I know it's been years since you posted to this thread, but I was wondering if you could help me. I recently tried clearing my codes by doing what you suggested, now my truck won't start. Actually, it won't even turn over. Any assistance would be appreciated. Thanks.
Old 10-25-2016, 06:55 PM
ligito ligito is offline
ligito is starting off with a positive reputation.
Tighten the ground cable.
Old 10-26-2016, 12:55 PM
mark224's Avatar
mark224 mark224 is offline
mark224 is starting off with a positive reputation.
Are dome lights dim, does the bells all sound when key is in. If no battery is loose. Removing the negative terminal is the way my mechanic told me to do it and has never failed. Check the terminal make sure it is clean and tight, if it is the slightest bit loose or dirty it will not make a good contact and won't turn over. Check your positive terminal also while you have the other apart clean and tighten.
Should start if everything is connected right . It will at least turn over.
If you do get it started the computer won't totally reset right away I was told to get it reset drive on the interstate 30 miles above the speed of 55 and it should be good for testing.
Old 10-28-2016, 11:36 AM
Quote:
Thanks mark224 and ligito for replying. To be thorough, I removed and cleaned all of the terminals and tightened securely. Still not turning over.
I get all of the normal bells, lights, fuel pump, etc. when turning the key to the 'On' position. When I turn to start, I hear a noise near the passenger side floor board. I'm wondering if it's something with the starter. Thoughts?
Old 10-28-2016, 11:55 AM
Chuck's First Ford Chuck's First Ford is offline
Chuck's First Ford is gaining momentum as a positive member of FTE.Chuck's First Ford is gaining momentum as a positive member of FTE.
alarm system? factory or otherwise?
Check engine light reset Cory1973 1999 to 2016 Super Duty 7 09-25-2015 08:24 AM
High and low idle skidley 1987 - 1996 F150 & Larger F-Series Trucks 1 08-17-2015 07:24 PM
Engine stalls Yaz-Lariat 2004 - 2008 F150 1 05-20-2015 04:27 PM
P0171 & P0174 on 4.2L V6 esvtrv 1997 - 2003 F150 8 02-21-2007 09:46 PM
Need help with High Idle problem (really long post) jcstratt 1997 - 2003 F150 3 02-01-2006 12:28 AM
Tags
03, 2008, 42, air, aviatior, check, codes, duty, engine, error, f250, filter, ford, light, obd, reset, super, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
