Boost leak detector - PICS! - Ford Truck Enthusiasts Forums
Old 03-14-2011, 12:05 PM
SkySkiJason's Avatar
SkySkiJason SkySkiJason is online now
SkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant future
This is sooooo cheap and simple I cannot believe I've not done it until now...
3" PVC cap tapped for a schrader valve:
You could get all fancy and tap a pressure gauge in there too - but its totally not necessary. The CCV, VC's, etc are gonna leak some and bleed the pressure down, so we just blow up the intake tubing until it looks uncomfortably inflated and start sprayin' soapy water and listening...
Remove airbox (or in my case 6637) and clamp PVC in place, then blow compressed air in and spray all boots, etc with soapy water:
I'm willing to bet more people have leaks than think they do... Most of that 'dirty engine' syndrome can be mitigated by eliminating leaks found with this EASY test.
Thanks to Jim (rat49F6) for loaning me this tool and all the other help he's been to me since I've been in NJ!!!
Old 03-14-2011, 01:02 PM
BillyBob69's Avatar
BillyBob69 BillyBob69 is offline
BillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to all
Great tip!
Reps given!
Old 03-14-2011, 05:19 PM
ScaldedDog's Avatar
ScaldedDog ScaldedDog is offline
ScaldedDog has a great reputation on FTE.ScaldedDog has a great reputation on FTE.ScaldedDog has a great reputation on FTE.ScaldedDog has a great reputation on FTE.ScaldedDog has a great reputation on FTE.
Dumb question, but where'd you get the Schrader valve?
Mark
Old 03-14-2011, 05:25 PM
Brother Les's Avatar
Brother Les Brother Les is offline
Brother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to behold
Keep your psi low or you will have 'leaks' everywhere
Old 03-14-2011, 05:34 PM
Good advice Les. Not sure how many psi I was putting in there, but guessing not more than 20-25... We just puffed up the intake tube a little and looked for leaks until it got soft again - then added more air (2-3 secs).
I'm surprised we haven't gotten any comments about the lovely hand model we used for this shoot!
Old 03-14-2011, 05:42 PM
I have a regulator on my air compressor, so I would suggest cranking it down to 20psi. Boys will be boys with the mindset of 'a little will help a little... so... lets go for a lot and.... really muke it up'
I need to make me one of those... I have the stuff laying around.
Old 03-14-2011, 05:48 PM
ron's power stroke's Avatar
ron's power stroke ron's power stroke is offline
ron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud of
here is mine i made about 5 years ago...
here is a nice one for 30 bucks
Intake Pressure Tester
Old 03-14-2011, 07:47 PM
76'SuperCab's Avatar
76'SuperCab 76'SuperCab is offline
76'SuperCab is starting off with a positive reputation.
Went ahead and made one of these today (thanks for the easy directions) and I'm afraid to ask about the results - why would air be coming out of the dipstick? I only pressured it up to about 20 psi and couldn't find any other "leaks."
Old 03-14-2011, 11:40 PM
timmyboy76's Avatar
timmyboy76 timmyboy76 is online now
timmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to behold
cool...another tool to make.
Old 03-14-2011, 11:48 PM
Turns out I made the mistake of hooking it up to the CCV coupler just like this. I'll try again later with the detector hooked up to the correct boot.
Old 03-15-2011, 12:54 AM
rat49f6's Avatar
rat49f6 rat49f6 is offline
rat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to behold
Quote:
Mark
schrader valve came from my B.A. local Hardware store
u would like those beat up hands
lets make a high class new tester like rons
Old 03-17-2011, 08:04 AM
Franko72's Avatar
Franko72 Franko72 is offline
Molon Labe
Franko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud of
Thanks for the cool idea Jason, I think I'll fab one up while my chip is out for updates......It's too booring and slow to drive anyhow.
I tried to rep you brother, but.....
Old 03-17-2011, 09:00 AM
joegebff's Avatar
joegebff joegebff is offline
Gone Fishin for Mark
joegebff has a great reputation on FTE.joegebff has a great reputation on FTE.joegebff has a great reputation on FTE.joegebff has a great reputation on FTE.
I got him for ya....
Old 03-17-2011, 09:16 AM
jwhitetail jwhitetail is offline
jwhitetail is gaining momentum as a positive member of FTE.
Quote:
I would say if you put enough pressure on it with the valves open it will bypass the piston ring's, the reason for CCV. Seems like if you wanted to check for leaks take the intercooler tube off at the cold side at the spider and plug with cap also.
Old 03-17-2011, 11:05 AM
Quote:
Not necessary... We don't need it to 'hold' pressure to check for leaks - just have some pressure in there so we see bubbles in our soapy solution. Anyway, the thing you are suggesting we disconnect is the most likely suspect for a leak... Besides, at least one intake valve is always open, right?
The intake tube goes directly into CCV - unlike gassers, there is no PCV - so air blown in the way I describe is pressurizing crankcase via valve cover. This would be a good reason to keep pressure low. You could plug CCV in intake tube and put as much pressure as ya wanted (until ya broke CAC) - but again, I think its totally unnecessary!
K.I.S.S.
and not needed, but thanks anyway Joe!!!!
Finally putting my X back on the road! SkySkiJason Excursion - King of SUVs 5 12-03-2012 03:24 AM
255/85/16 M55's on MY dually!! (pics too) SkySkiJason 1999 - 2003 7.3L Power Stroke Diesel 32 09-06-2012 01:57 PM
time to hook up mirror heaters SkySkiJason 1999 - 2003 7.3L Power Stroke Diesel 31 02-03-2011 08:32 AM
FPHE + poly + sawzall = PICS of carnage!! SkySkiJason Bio-diesel, Propane & Alternative Diesel Engine Fuels 2 01-07-2011 08:24 AM
1 hole and at least 3 cracked pistons - pics SkySkiJason 1999 - 2003 7.3L Power Stroke Diesel 166 01-20-2010 07:11 PM
Tags
2006, 60, 64, 73, 99, boost, detector, f350, find, ford, leak, lightning, powerstroke, tester, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
