2010 F150 6spd. trans. fluid level - Ford Truck Enthusiasts Forums
Old 03-14-2011, 08:22 AM
mikey v mikey v is offline
mikey v is starting off with a positive reputation.
OK; I give up. How do I check the trans. fluid level on my 2010 F150 6 spd. auto trans????? I see that there is NOT a dipstick in the engine compartment. I have searched around on here, and cannot find an answer.
Thanks, in advance; for your help............
Old 03-14-2011, 08:56 AM
blueeyedfordguy's Avatar
blueeyedfordguy blueeyedfordguy is offline
blueeyedfordguy is starting off with a positive reputation.
Car companies are starting to "remove the dipstick" from the engine bay. Well, i have read that the new automatics are going to a check plug like on a manual transmission or differential. You see, the manufactures are getting tired of people over filling these transmissions which eventualy causes excessive wear and failure. Imagine a blender, when you over fill this fluid its like it gets churned, because it gets oxidized, which breaks down any fluid a lot quicker. The fluid does not hold up as well or cool so the transmission gets burned up. If you have checked or changed the fluid in a manual transmission you will know what im talking about. There is a fill plug about half way up the transmission case. When you remove this plug then You can usually fit a pinky finger in there to see where the transmission fluid is. If its low fill it till it flows out the threads then, cap it. I believe your suposed to check the fluid when its cold. Although, I am not sure. Hope this helps. This should be the case for you if there is no dipstick in the engine bay.
Old 03-14-2011, 09:00 AM
Thx. for the info!
Old 03-14-2011, 09:10 AM
Let me know what you find out. It makes sence to me. I have always liked filling a manual transmission because you know when its full (when it pours out!) I hate tring to read the dipstick on automatics and tell how much fluid is in one. Its hard to see for me. So, i can see why people over fill them by mistake possibley. Tell you what i have no problems what so ever seeing how much engine oil there is in a cold engine though. I believe its due to the engine oil being thicker and darker.
Old 03-14-2011, 11:18 PM
brcman brcman is offline
brcman is starting off with a positive reputation.
read manual
My 2010 owners manual says there is no need to check it, if you think it needs attention go to the dealer. It also says the fluid is designed to last a lifetime. I assume it is a synthetic, I really do not like this situation.
Oldstuff
Old 03-15-2011, 06:55 AM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
Quote:
Oldstuff
It's MERCON LV fluid. My 2010 Focus has a 150K mile transmission service interval where the manual states to have the tranny flushed and the filter replaced. It will be the same or similar on the F-150:
Unless,
You are towing all the time, or working your truck pretty hard. Then the service interval should drop significantly.
Old 03-15-2011, 09:43 AM
Its not that i dont believe you guys, its that those are some scarey intervals truethfully! "Lifetime fluid" and 150K ouch! My car just rolled 150,000 not to long ago and the transmission slipped this winter. That was just from the fluid not being changed the last 60k miles i believe that, and it did it when it was bitter cold. If you think about it all transmission fluid breaks down over time. Synthetic or not synthetic. Both synthetic and non synthetic will get moisture in them over time, theres reasons to change transmission fluid before 150k. Im not sure what ford is trying to acomplish by this either. Honestly, does not sound like it makes them tougher or make ford trucks look tougher. I really dont like these ideas...
Old 03-15-2011, 06:09 PM
tseekins's Avatar
Quote:
No one said you can't change the fluid when ever you want. These are simply Ford's guidelines and "not exceed" numbers. I will have no problem at all taking Ford's recommendations to task.
Ford's overall goal is to reduce the cost of ownership by reducing maintenance intervals. I think it's a wonderful idea.
Old 03-15-2011, 09:09 PM
Ranger Lance Ranger Lance is offline
Ranger Lance is starting off with a positive reputation.
Talked about it here:
http://www.ford-trucks.com/forums/89...-dipstick.html
Post #10 outlines the procedure to check the fluid level
Old 03-16-2011, 08:17 AM
Ranger Lance--Thanks much for the link! Thanks to all who responded; I am now trained up! Mikey
Old 03-16-2011, 11:24 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
It's not a new thing. The Mustangs have been this way since 2005. On the plus side, you can easily slide under the truck to check it vs having to either put the Stang on a lift or jack up the front and rear to keep the car level to check it
Old 03-16-2011, 06:18 PM
TrapperDave's Avatar
TrapperDave TrapperDave is offline
TrapperDave is starting off with a positive reputation.
Great Subject Folks! I was also wondering how to check my tranny fluid (2010 F150). Thanks for the pot and informative replies.
Old 04-25-2011, 09:06 AM
prtermite1 prtermite1 is offline
prtermite1 is starting off with a positive reputation.
2010 f150
My 2010 F150 has the 6spd auto and the manual says to flush system every 30000 miles and to change the fiolter at 90000. I have 40000 and had it flushed this weekend for 179.00 and it shifts a lot smoother
Old 04-27-2011, 09:02 AM
Yeah im changing the transmission filter and fluid in my 1998 mecury tracer. The owners manual has no interval or even what type of fluid it even takes. I checked chiltons libary on line and all data. Ford has no change intervals for normal opperating conditions or severe service. Interesting... The recomendation is when the fluid gets gritty, discolored, or smells burn that is when it needs to be replaced. I guess it makes sence, but i would think it should be replaced at least every 30 to 60,000 miles.
Old 05-06-2011, 02:29 PM
tWyStyD's Avatar
tWyStyD tWyStyD is offline
tWyStyD is starting off with a positive reputation.
Oldstuff
It doesn't last a lifetime, my service sched for my '09 says remove, flush and replace, every 50k, and it isn't cheap
Sounds excessive to me
Transmission sticking and getting hard to shift jarhead2147 1987 - 1996 F150 & Larger F-Series Trucks 0 09-06-2014 05:36 PM
transmission code GVS 2009 - 2014 F150 3 12-19-2012 02:27 AM
how to check fluid in e9ta ca transmission eithernet2010 1987 - 1996 F150 & Larger F-Series Trucks 9 10-19-2010 09:23 PM
what type of manual tranny fluid for 89 f150 5spd?? geotracker91 1987 - 1996 F150 & Larger F-Series Trucks 6 09-09-2008 05:15 AM
Lifetime auto-tran fluid? mwh 2004 - 2008 F150 5 07-11-2004 01:34 PM
Tags
2010, auto, change, check, differential, difftrans, f150, fluid, ford, level, oil, replacement, speed, trans, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
