EBPV solenoid
Well, if i understand correctly, there have been oiling issues related to the dynamics of oil pressure being allowed to flow through the EBPV piston cavity once it's gutted. The pedestal is designed to maintain a certain oil pressure based on the components originally installed, and without a job to do, oil flow, when the PCM commands the solenoid open, can rob the turbo of oil pressure. I would just do what many (including myself) have done- install a resister across the terminals of the engine harness plug for the EBPV solenoid, and be done with it.
I have the pedastal delete on mine and just have the plug wrapped and hanging but have been wanting to do something with it. I know there is a "plug" you can buy (Dieselsite maybe?). What specific resistor would I need to buy? Is there a particular "direction" it needs to be soldered?
Hope that helps!
on
Yeah, i just went the cheap route, bought a resistor pack from Radio Shack for $1, folded the ends so it would plug right into the engine harness side of the solenoid connection (NOT the solenoid itself) and then taped it up to keep out the weather. If i get some time i'll cut the connector off, and solder the resistor inline properly. Oh, and resistor direction doesnt matter. Here's a pic of the Radio Shack package, with part number and specs. You could go up to a watt as well, not just the 1/2 watt.
Hope that helps!
Hope that helps!
I used the same size resistor when I deleted my wastegate solenoid also.
on
This is exactly the type of thread with the resistor for the EBPV I was looking for? Roland, it looks like you have a picture of two different resistors which on did you use and what size was it? Are these resistors the same size you all have used on the AIH delete method as well?
I used the same 470 ohm resistor in the AIH, WG solenoid, and EPBV solenoid deletes. 2001 Ford F250 4x4 - AIH Code Eliminator
It goes in line from the post on the relay to the engine ground the ground wire from the AIH was connected to. I am planning on making mine in the next couple of days and can take pictures. I also installed my resister in the EBPV connector and it is working great with no SES light unlike the last time I disconnected it.
E55 Bulldog
07-25-2020 03:01 PM
Snowseeker
55
06-25-2016 09:10 PM
