Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > California, Northern Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
California, Northern Chapter Join Chapter , Leader: Nighteyez
  #1 (permalink)
Old 03-13-2011, 11:16 PM
RJM4u RJM4u is offline
Garage is empty, add now
RJM4u is starting off with a positive reputation.
Sudden powere loss at ignition sw.
I have a 1975 F250 Ranger XLT and today the power to the ignition, lights and fuse panel disappeared. There is 12V at all 4 terminals of the start solenoid when the key is on and to the regulator. Fusible links under the hood are all ok. HELP!
  #2 (permalink)
Old 03-13-2011, 11:38 PM
aawlberninf350's Avatar
aawlberninf350 aawlberninf350 is offline
Elder Blossom Wine
aawlberninf350 has a very good reputation on FTE.aawlberninf350 has a very good reputation on FTE.aawlberninf350 has a very good reputation on FTE.
My first guess would be fusible link, but you checked that. Is it a camper special? More fusible links to look at in that case. Does it crank but not fire? Is the ignition switch ok or worn and floppy?
__________________
David
2002 F350 7.3 CCSB 4X4 sleeved AIS WW Mishimoto 6.0 IC 6.0 trans cooler 26 row RiffRaff: FRx Plenum Reinforcers AIH Delete Boots
Isspro EVs 50 cent mod Foil delete Hutch Harpoon DP Tuner Walker BTM 4R100 w/FTVB nlemerise AC mod Mile Marker 449ss RedHead 08 diff cover Fumoto DDM HID 55w 4500k Bilsteins DieselSite Coolant Filter Donaldson ELF7405
  #3 (permalink)
Old 03-14-2011, 01:22 PM
Sudden loss of power on F-250
The ignition sw is fine. It is a camper spl. It is completely dead. No power to the fuse blocks or to lights or to the ignition sw. Disappearing somewhere between the input post on the starting solenoid and the ignition sw. I have ordered a new starter solenoid since this one has no reading on the coil.
  #4 (permalink)
Old 03-15-2011, 12:23 PM
joe f350's Avatar
joe f350 joe f350 is offline
joe f350 has a good reputation on FTE.joe f350 has a good reputation on FTE.
what shape are ur battery cabels and grounds in
__________________
the panzer 85 with a 97 front clip ford f350 lifted dana 60 37 6.9 t19 none wasted banks turbo 87 6.9
Quote:
Originally Posted by alpha/omega View Post
aaahhh, good ol' FTE.
The wealth of misinformation around this place is epic.
  #5 (permalink)
Old 03-15-2011, 12:38 PM
Battery cables good, clean and tight
Tags
2007, 54, dead, f350, ford, ignition, lossing, spark
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
