Code 212 in memory
Code 212 in memory
Drove home from work today. Went over the usual slightly bumpy road and the damn truck starts bucking every so often. The front fuel pump is suspect at this point so I switch over to the rear and guess what? It still bucks and loses power randomly. Pull over to let traffic go and I just take it easy the rest of the way. Once I get home I decide to check codes for the hell of it. KOEO pass, 111. When I get to continuous memory I get 212 and 628. I looked up 212 and it is described as a loss of IDM input to the PCM. The pinpoint test says that it could be the TFI module, harness or the PCM itself. The TFI module was replaced ~4 years ago. Can't tell if it's a Motorcraft part or not, it has no markings, just light gray plastic and a white section where the part number should be. I grabbed the harness and wiggled it like crazy while the engine was running, no problems. Wiggled the PCM harness, no problems. So ... order a new TFI module or crack open my PCM?
Update: have not had a chance to actually check the wiring ... Cleared the codes and drove to lunch and back. Truck runs normally, no loss of tach signal or power. Checked codes again and it's STILL throwing 212. No symptoms showing yet but I will check wiring tomorrow. Rla where is the 22K resistor physically located in the harness?
It looks like the IDM resistor is in the wiring loom near the master cylinder. Found this post: Code 212 help needed - Ford Bronco Forum
It has a photo
May be in a different location for a 1991, but should be close.
It has a photo
Yeah I've heard that's usually the case with these TFI modules ... It's just so random though, seems like it wants to die out of nowhere. It only lasts a split second and regains power. The consensus of my coworkers is that if a TFI module is bad, it usually doesn't wake up - when they die, they stay dead.
PIP signal is monitored on Pin 56 of the computer. Pin 4 is IDM. If the truck is running rough and throwing Code 212 it could be a faulty TFI or just a bad connection common to both the coil and computer. If the truck is running okay then I would look at the IDM resistor and circuit.
Edit: Checked between the coil connector and pin 4 of the PCM with it all unplugged and got 21.5K ohms, they want at least 22K ohms. Wiggled the harness and BOOM it goes OL on my meter. That wire must be damaged?
