AC pulley squeak
AC pulley squeak
There's a squeak coming from the pulley on my wife's truck. AC still seems to function fine in these mild 70 - 80 deg temps. Does anyone know if the squeak could be fixed by replacing the clutch / pulley or does it typically come from deeper within the compressor?
It's been too long since I changed mine to remember how it looked and what part might be the source of the noise.
Yes, the clutch bearing needs a change-out.
The bearing COULD be changed if you wanted to go to the trouble, as it's just swedged in there. You'd need a hand-grinder and maybe a press to do it, though.
The entire clutch assembly should be able to be had for around $130 or so. However, I'm not sure you won't have a lot of time into it by the time you change the bearing alone.
Here's a write-up on it:
https://www.ford-trucks.com/forums/9...ml#post8676261
Pop
Pop
Does it squeak while engaged? If not, probably the bearing on the pulley, if so... I'd be looking at other pulleys. Compressors usually don't "squeak". Also take a look at the hood liner and see if there is a "spray line" over the top of where the compressor is. Good sign your front seal is giving up.
I just serviced my A/C bearings. Had the belt off and the pulley wasn't spinning freely, so I removed the pulley, carefully removed the dust shields on the sealed bearing, brake cleaned and repacked it. Dust shields snapped back in and whala, G2G. (The original grease looked like it had turned into WAX)
Caught early enough, before any bearing damage, this is very cost-effective P/M for a Saturday morning!
Pop
Thanks Pop. That was the kind of info I was looking for. Pressing out the bearings doesn't bother me, finding the correct size bearings sounds like it might be a pain. Replacing the clutch might be the way to go. Wish I had kept my old one to take apart and play with.
No signs of a seal leak Casper. The noise happens both with the AC on and off, but when you turn the AC on, the noise becomes more constant. It also only happens while driving, not at idle. We were able to confirm it yesterday on the freeway. Switch the ac on and off repeatedly and the noise is most definitely tied to the AC.
Spinning the pulley by hand with the belt off gives a little hint of a noise. I've confirmed it's not the idler or tensioner.
Chris, sounds like your onto the problem, bear in mind, when the compressor is active, it's going to put a load on the belt. Have you tried squirting a mild soap solution onto the belt and pulleys? My last belt actually started to "squeak" like the old V-belts.
If it is the compressor, I'd guess it must be the front bearing. Don't think I've seen a front bearing start to go without the seal beginning to fail first though.
Catch it early enough, and all it takes is a bearing. Seal will still be intact if you're quick.
A good cleaning of the snap ring area with solvent and a brush facilitates removal.
I'd just leave the coil alone.
Pop
Barry, I'll let you know. I want to check the air gap and pull and inspect the pulley and stuff first. If anything else looks worn, I might as well replace the whole clutch. If it's just the bearing, I'll get the number from you. I've got to be in Ft Worth Tuesday, so that might work out.
