01 F150. can i use e85? - Ford Truck Enthusiasts Forums
Old 03-13-2011, 06:19 PM
Ravenwood Ranch's Avatar
Ravenwood Ranch Ravenwood Ranch is offline
Ravenwood Ranch has a good reputation on FTE.Ravenwood Ranch has a good reputation on FTE.
I don't.have. the book but I.want to use e85 has a 4.6 and is a 4x4
Old 03-13-2011, 08:34 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
No, you cannot.
Old 03-13-2011, 10:20 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
computer is not calibrated for that, and you will probably screw up the O1 sensors. Ethanol gas is 10% and that works o.k. I think you can run about 30% without problems, not 85%
Old 03-13-2011, 11:59 PM
So put like 5 gallons e85 with the rest regular
Old 03-14-2011, 09:03 PM
steve(ill)'s Avatar
if you insist, but your milage will drop and probabl break even considering the cost of the E85. dont bother.
Old 03-14-2011, 09:26 PM
Damn ok !!
Old 03-16-2011, 10:44 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Ethanol is corrosive and at levels much over 10% will start eating away at your fuel system. Flex fuel vehicles have fuel system components that are designed to cope with the ethanol as well as you need to increase the injector pulse and move the timing to get the same power output from e85 as you do Gasoline. E85 has a much lower BTU output so it takes a lot more e85 to be injected into the cylinders.
This is why if you look at a window sticker of a flex fuel vehicle, the miles per tank is considerably lower on e85.
Short answer, NO
A tank of E-85 after 40,000 miles? 640 CI Aluminum FORD 2009 - 2014 F150 35 06-29-2016 01:33 PM
Ethanol in my v 10? KP1001 Modular V10 (6.8l) 9 05-27-2016 09:57 AM
Can E85 damage engine if never used in past? bluegroove Ranger & B-Series 15 03-05-2011 12:34 PM
E85 in a carb engine? staysbroken Alternative Fuels, Hybrids & Mileage 17 09-10-2007 08:06 PM
e85 flex fuel?? MILLHOUSEB Alternative Fuels, Hybrids & Mileage 34 09-14-2006 04:13 AM
Tags
02, 2000, 2001, 2002, 2004, 2007, 2010, e85, ethanol, f150, f250, ford, gas, truck, usee85
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
