18" or 20" inch Wheels.
#46
When you do, check their load carrying capacity. That is usually the trade off in the larger rims, lower overall strength for a larger rim.
#47
https://www.fleet.ford.com/truckbbas...Pickups_SB.pdf
Page 81 of document at above link has factory tire load ratings and factory wheel load ratings. Full specifications for rims and tires.
Below is summary of SRW ratings:
LT245/75Rx17 3195 lbs.
LT245/75Rx17 3195
LT265/70Rx17 3195
LT275/65Rx18 3415
LT275/70Rx18 3640
LT275/65Rx20 3750
17" x 7.5" J 3195 lbs.
18" x 8.0" J 3590
20" x 8.0" J 3590
Max Rear Axle Rating (ignoring springs, etc.; raw axle rating)
F250: 6200 lbs.
F350: 7280 lbs. (srw)
For 20" the tires will be the limiting factor; not the rims or axle as 2*3590=7180 lbs if for F-350; but the axle will be the limiting factor for the F250. (Ignoring other ratings by Ford for the load carrying capacity.)
Bob
LT245/75Rx17 3195
LT265/70Rx17 3195
LT275/65Rx18 3415
LT275/70Rx18 3640
LT275/65Rx20 3750
18" x 8.0" J 3590
20" x 8.0" J 3590
F250: 6200 lbs.
Bob
#48
