Installing tach cluster in non tach cluster truck?
Howdy guys
Next week i'm gonna start striping down my 1988 F150 parts truck, it's a 300-6 5 speed and my driver is a 1989 F150 300-6 C6.
The 5 speed truck has a factory tach and my '89 has the basic dash.
It is hard to swap over the tach cluster to my '89?
I also wanna keep the original mileage to the 89 truck, in the 89.
It is easy swaping over the odometer. also? The tach cluster has a trip odometer.
Is the connector already in the '89 ready to hook up to a tach cluster?
Your truck is pre-wired for a tach, so it should work as long as nobody has messed with the wiring.
Non-tach cluster are three piece clusters (volt&temp, speed indicator, oil & fuel) and tach cluster are four piece clusters (volts & temp, oil & fuel, speed indicator, tach). The speed indicators might be interchangeable (as far as size), but the rest are not. If the speed indicators are the same size, then it just a matter of popping them out and swapping them.
You will be better off just using the tach cluster as a whole and running the odometer on it to what ever mileage you want it to read with a drill.
When you take it out of you parts truck, take out the speedo cable also. With both the cluster and cable out of the parts truck, hook the speedo cable back up to the cluster and a drill to the end of the cable that goes into the tranny. Then you can set it to the mileage thats on your other cluster that you are taking out of your other truck.
Hope this helps!
Hope this helps!
When you take the tach cluster out of you parts truck, take out the speedo cable also. With both the cluster and cable out of the parts truck, hook the speedo cable back up to the cluster and a drill to the other end of the speedo cable that would go into the tranny. Run the drill forward to increase the mileage numbers or run the drill backwards to decrease the mileage numbers, you can set the mileage to match the mileage thats on your other cluster that you are taking out of your truck.
This is the same way I set the mileage on the tach cluster that I put in my truck. Its easy to do this way and it does not require you to take anything apart on the cluster that would mess up the numbers or make them loose.
Bluethunder3320
04-06-2014 08:12 AM
Handegard
02-22-2014 11:27 AM
f100beatertruck
09-14-2013 01:25 PM
Nathan Plemons
06-14-2013 01:56 PM
droppedf100
02-23-2009 10:19 PM
