scangauge ?s
Here are the 3 different sets of parameters for the FICM posted by Robs97z28 in another thread.
FICM Vehicle Power (Volts) (Should be 12 Volts)
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 0064010000000
NAM: FVP
<ACRONYM title="Fuel Injector Control Module">FICM</ACRONYM> Logic Power (Volts) (Should be 12 volts)
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 0064010000000
NAM: FLP
<ACRONYM title="Fuel Injector Control Module">FICM</ACRONYM> Main Power (Volts) (Should be 47-48)
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 0064010000000
NAM: FMP <!-- / message -->
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 0064010000000
NAM: FVP
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 0064010000000
NAM: FLP
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 0064010000000
Here is the link from the OP on another thread:
Scangauge II FICM - PowerStrokeNation
DieselStroke figured these out.
if one could figure out that page on scan gauge web site about the programming it should be able to show everything that comes to the obdII port. I tried reading it yesterday but Im not that smart it might as well be writen in chinese. if anyone can explan this in a simple way I would apprecate it
We need to compile a list of all known 6.0 codes and put them in one thread that can be updated when new ones are found
And also, my MAP and boost do the same thing. I'm going to re enter the boost today and see if I had something entered wrong.
