Can you explain how the 4wd works? - Ford Truck Enthusiasts Forums
Old 03-12-2011, 02:35 PM
flavo flavo is offline
flavo is starting off with a positive reputation.
My tires are bald and I know that does not help my situation at all. I'd like to know how the 4wd system works though. I got stuck yesterday in a bit of snow and ice off road. I noticed that only the right side was spinning. Before the right side started spinning the left was though. I always assumed with the hubs locked both the R&L would spin.
I have warn lockers and the hubs were locked btw.
Old 03-12-2011, 03:27 PM
MR5x5 MR5x5 is offline
MR5x5 is gaining momentum as a positive member of FTE.MR5x5 is gaining momentum as a positive member of FTE.
Something is not right?? Are you sure you have WARN Lockers, or do you mean WARN Hubs. They are not the same. If you have lockers, front and/or back, then both tires turn. Period. If you're stock you most likely have limited slip. If so, and you can't make traction you will get "limited slip." I'm assuming you had at least one front tire spinning, hence your 4WD was engaged. Did you manually lock the hubs?
Old 03-12-2011, 03:55 PM
binuya's Avatar
binuya binuya is offline
binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.
If you are stock, you do not have limited slip on the front axle. Even if you lock both hubs, the side with no traction will spin. Locking the hubs will not lock the differential.
Old 03-12-2011, 04:00 PM
SpringerPop's Avatar
SpringerPop SpringerPop is online now
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
The front differential is an "open" differential, not limited slip or locker-type. You really want it to be that way. Otherwise, things get kinda' "squirrely", especially in turns, and even more-so on ice.
The idea of "locking" comes from the fact that you "lock" the front drive axles to the front drive hubs with the front "hub locks".
What you call "hubs" are actually "hub locks". They are the things you turn to lock.
The "hubs" are what the front tires and brake rotors bolt onto, and which contain the front wheel bearings.
Old 03-12-2011, 05:52 PM
I'm sorry for the misinformation. I believe what I mean to say is that I have warn locking premium hubs that I recently installed because the old ones stopped working. So I guess my 4wd system is working properly then as long as one front tire was spinning?
Thanks, Mike.
Old 03-12-2011, 06:00 PM
Again, these are not hubs. They are hub locks.
Yes, it's confusing, but maybe not so much now.
Pop
Can I engage 4wd if 1 hub lock is broken ? Steven Stocki 6.0L Power Stroke Diesel 3 12-04-2016 08:01 PM
Need some help/advice on 4wd for 67 F250 curioduo 1967 - 1972 F-100 & Larger F-Series Trucks 1 08-06-2015 09:22 PM
4WD Hub Stuck Locked pgguru Excursion - King of SUVs 9 12-11-2013 09:40 PM
4x4 not working, unusual problem? ksidlosky Offroad & 4x4 8 04-02-2013 08:23 PM
03 F350 4x4 Troubleshooting - Hubs Locked - Problem Resolved! Brett W 55 Ford 1999 to 2016 Super Duty 15 03-03-2012 04:52 PM
Tags
2001, 2005, 4wd, 73, drive, f150, f250, f350, ford, front, hubs, lock, older, wd, wheel, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
