Torque specs for front wheel bearings??
Old 03-12-2011, 10:41 AM
Sixoh's Avatar
Sixoh
Sixoh is offline
Replacing my '01 B3000 hubs and don't have a tech book for it! I know. I'm ashamed.
Anyway, what is the torque on that spindle nut??? Pleeeeaaassee???
Old 03-12-2011, 11:24 AM
03 Maz B23's Avatar
03 Maz B23
03 Maz B23 is offline
Initial torque while rotating disc 21 ft lbs. Loosen spindle nut 175 degrees. Retorque to 17 inch lbs while rotating disc.
Old 03-12-2011, 01:48 PM
03 Maz B23's Avatar
03 Maz B23
Brake Rotor (Brake Disc)
Removal & Installation
Front
To Remove:
Remove the front disc brake caliper anchor plate.
On 4x4 vehicles ONLY: Remove the brake disc.
On 4x2 vehicles ONLY: Remove the brake disc and hub.
If necessary on 4x2 vehicles, resurface the brake disc and hub.
To Install:
On 4x4 vehicles ONLY: Clean the brake disc then place it on the wheel hub.
On 4x2 vehicles ONLY: Clean and examine the front wheel bearings and the brake disc and hub. Next, lubricate the front wheel bearings with the correct type of grease and install a new wheel hub grease seal then install the brake disc and hub.
Tighten the spindle nut as you turn the brake disc and hub.
Torque to 21 ft-lb (28.5 Nm).
Loosen the spindle nut by turning counterclockwise 175°.
Tighten the spindle nut while rotating the brake disc and hub.
Torque to 17 in-lb (2 Nm).
On 4x2 vehicles ONLY: Install the nut retainer, cotter pin, and hub grease cap.
Install the front disc brake caliper anchor plate.
Old 03-12-2011, 05:56 PM
Sixoh's Avatar
Sixoh
Sixoh is offline
That's why I'm a member of this site - priceless assistance!
I'm good on my old truck, but the '01....up to now it's just been an appliance. Now it's getting taken care of and getting the attention it needs
fatbs
08-16-2016 10:39 AM
shadow6777
10-22-2015 04:29 AM
eduardoCam00
6.4L Power Stroke Diesel
11-16-2010 08:17 PM
mhenneboehle
04-02-2010 09:38 PM
Titantis
10-25-2007 11:10 PM
Quick Reply: Torque specs for front wheel bearings??
