Torque specs for front wheel bearings?? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 03-12-2011, 10:41 AM
Sixoh's Avatar
Sixoh Sixoh is offline
Sixoh is starting off with a positive reputation.
Replacing my '01 B3000 hubs and don't have a tech book for it! I know. I'm ashamed.
Anyway, what is the torque on that spindle nut??? Pleeeeaaassee???
Old 03-12-2011, 11:24 AM
03 Maz B23 03 Maz B23 is offline
03 Maz B23 is gaining momentum as a positive member of FTE.
Initial torque while rotating disc 21 ft lbs. Loosen spindle nut 175 degrees. Retorque to 17 inch lbs while rotating disc.
Old 03-12-2011, 01:48 PM
Brake Rotor (Brake Disc)
Removal & Installation
Front
To Remove:
Remove the front disc brake caliper anchor plate.
On 4x4 vehicles ONLY: Remove the brake disc.
On 4x2 vehicles ONLY: Remove the brake disc and hub.
If necessary on 4x2 vehicles, resurface the brake disc and hub.
To Install:
On 4x4 vehicles ONLY: Clean the brake disc then place it on the wheel hub.
On 4x2 vehicles ONLY: Clean and examine the front wheel bearings and the brake disc and hub. Next, lubricate the front wheel bearings with the correct type of grease and install a new wheel hub grease seal then install the brake disc and hub.
Tighten the spindle nut as you turn the brake disc and hub.
Torque to 21 ft-lb (28.5 Nm).
Loosen the spindle nut by turning counterclockwise 175.
Tighten the spindle nut while rotating the brake disc and hub.
Torque to 17 in-lb (2 Nm).
On 4x2 vehicles ONLY: Install the nut retainer, cotter pin, and hub grease cap.
Install the front disc brake caliper anchor plate.
Old 03-12-2011, 05:56 PM
Sixoh's Avatar
That's why I'm a member of this site - priceless assistance!
I'm good on my old truck, but the '01....up to now it's just been an appliance. Now it's getting taken care of and getting the attention it needs
Torque fatbs Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 08-16-2016 10:39 AM
injector torque specs mhenneboehle Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 04-02-2010 09:38 PM
More horsepower and torque? crestfallinman Ford Inline Six, 200, 250, 4.9L / 300 16 03-10-2008 08:55 PM
torque specs 223 mpenni Ford Inline Six, 200, 250, 4.9L / 300 5 08-31-2003 10:44 AM
torque specs on 9in factorystock Clutch, Transmission, Differential, Axle & Transfer Case 7 06-27-2002 02:38 PM
Tags
2002, 4x2, bearing, bearings, f350, ford, front, hubs, nut, ranger, specks, spindle, tork, torque, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
