Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
What size Allen to remove caliper for brake pad change on 2008 Ford Escape V6 2wd
Old 02-23-2010, 02:43 PM
zrt600guy's Avatar
zrt600guy
zrt600guy is offline
If you can help, I would sure appreciate it! Thanks
Old 10-10-2011, 06:58 PM
nick1154's Avatar
nick1154
nick1154 is offline
allen wrench
Do no try to remove those the are factory set in lock tight , use the mounting bolts to remove from vehicle and make sure you grease those allen bolts good to insure calipers dont hang up . Also use ceramic brake pads they should last about 60K miles on these cars . also if you are new to the escape if you hear a whirring sound from the rear the back tires are suseptable to cupping I have owned a couple and the company I worked for did too actually very low matainence cars
Old 10-10-2011, 07:00 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
https://www.ford-trucks.com/forums/1...placement.html
Old 10-22-2011, 08:28 AM
pettermax's Avatar
pettermax
pettermax is offline
I like this forum, great!
Az58Cameo
45
12-07-2013 01:21 PM
largefries
09-07-2012 08:37 PM
wrench11
1999 to 2016 Super Duty
09-18-2009 11:44 AM
deyomatic
07-12-2009 11:50 AM
Quick Reply: What size Allen to remove caliper for brake pad change on 2008 Ford Escape V6 2wd
