Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 03-11-2011, 09:59 PM
Philip Berardi's Avatar
Philip Berardi Philip Berardi is offline
2000 Ford F-250
Philip Berardi has a very good reputation on FTE.Philip Berardi has a very good reputation on FTE.Philip Berardi has a very good reputation on FTE.Philip Berardi has a very good reputation on FTE.
picture of magnesol pump
anyone have a pic of this..mine decided that it dosent want to work. i have it on the floor with a 8 ft hose in the tank, and a hose going to the filters...wont work...
just looking for a pic.
thanks guys
__________________
Philip Berardi - 2012 F250 Lariat CC SB FX4 - Weather Tech Floor Mats / AVS Vent-Visor / H&S (on the closet shelf until 35k )/DRL/Switch Back Mod
  #2 (permalink)
Old 03-11-2011, 10:04 PM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
my pump is a diaphragm pump from dudadiesel, was about $100. I need to get out tomorrow and update pics...
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #3 (permalink)
Old 03-12-2011, 11:23 AM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
thanks guys
Do not pump your bio with the Magnesol in it in any vane, gear or impeller style pump! Either use a diaphragm pump, or better yet let it settle and then pump the bio off the top. Pumping bio with Magnesol suspended in it will result in a "shearing" of the Magnesol into finer particles that will make it extremely hard to remove.......
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #4 (permalink)
Old 03-12-2011, 02:44 PM
2000 Ford F-250
Fabman- I understand that. I am just trying to figure out how uguys pump ur bio off the top. My pump wouldn't get suction. Just wanted to see what u guys used
  #5 (permalink)
Old 03-12-2011, 02:55 PM
1935 Ford pickup
I use an air powered diaphragm pump.........
__________________
  #6 (permalink)
Old 03-12-2011, 07:11 PM
2000 Ford F-250
Pictures and I am tyring to figure out how I can put a lot level strainer on tjhe bottom to put thje hose in there and let it rest on the magnesol but not suck it up. Where did u get the air powered pump?
  #7 (permalink)
Old 03-12-2011, 09:14 PM
1935 Ford pickup
This is the type of air powered pump I use:
Click the image to open in full size.
__________________
  #8 (permalink)
Old 03-12-2011, 09:55 PM
zhilton's Avatar
zhilton zhilton is offline
2004 Ford F-250
My Garage
zhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to all
This is just a thought....
Sandpiper Air-Operated Double Diaphragm Pump — 1/4in. Inlet, 15 GPM, Polypropylene/Buna, Model# S05B2PBTPNS000 | Air Operated Oil Pumps | Northern Tool + Equipment
Your local truck supply (TruckPro) should have it...or know who would have 'em.
__________________
FTE Arkansas chapter member
1972 Ranchero GT (351C CobraJet intake)
2001 Explorer XLT 2WD
2004 F250 6.0L 2WD CC "Pavement Princess"
2007 Monaco Starwood SL 31BHD
2012 Focus SEL (Wife's ride)
  #9 (permalink)
Old 03-12-2011, 11:06 PM
2000 Ford F-250
i just dont get how you are using that with the magnsol and not picking it up off the bottom.
i was planning on getting the pump from dudadisel and connecting 3/4" hose to it and sucking the finished product essentially off the magnesol, when i saw the magnesol i would stop. is that what you guys do? just seems like a lot of work.
__________________
  #10 (permalink)
Old 03-13-2011, 06:49 AM
Rushmore X's Avatar
2003 Ford Excursion
have it hooke to a pvc pipe that I lower to above the level of the magnesol. Per another suggestion, I am going to make a p-trap on the end so it draw down rather than up....
__________________
Tags
magnesol, pictiure, pump, stop, type, ur
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
