Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > 2011 & Newer Explorer
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2011 & Newer Explorer Discuss the all new redesigned Ford Explorer SPONSORED BY:
  #1 (permalink)
Old 03-11-2011, 06:35 PM
RhinoScores RhinoScores is offline
Garage is empty, add now
RhinoScores is starting off with a positive reputation.
New Explorer offroad capabilties?
I wasn't sure which thread this question shouold go into, but I have a 2007 Explorer with the V6 that I use offroad, mostly in loose sand on the beach, for fishing. Does anyone know the capabilities the new Explorer in 4x4?
  #2 (permalink)
Old 03-13-2011, 03:00 PM
wwest wwest is offline
wwest is starting off with a positive reputation.
Quote:
No 4X4 or even 4WD capability.
FWD or F/awd only. SOLID coupling to the front drive and "soft", dynamically adjustable, drive to the rear. Patently UNSAFE even on wintertime adverse condition, slippery, roadbeds, let alone off-road.
  #3 (permalink)
Old 03-13-2011, 10:22 PM
No 4x4 selector switch? Well that blows since many beaches don't allow full time AWD vehicles on the beach as they tend to dig themselves into the sand. Guess I'll have to keep the 2007 or perhaps get a one of Jeep's products ot a Tacoma.
  #4 (permalink)
Old 03-14-2011, 07:54 AM
MCDavis's Avatar
MCDavis MCDavis is offline
MmmmmmKayyyyy
2006 Ford F-150
MCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputation
WWest, what data do you have to support your claim?
While the "4wd" Explorer is really all wheel drive, meaning you cannot select between 2wd and a 4hi or 4low, and all wheels are somwhat powered even on dry pavement. The Terrain Management System (very closely related to that found on the Land Rover LR3 and Range Rover, very capable off roaders I might add) does allow for adjustments in the drivetrains response and "nanny controls" like throttle response, stability control, wheelspin, etc.
Sure, the 2011 Explorer is no rock crawler, but should be well suited for the average users off road needs. Meaning conditions like mild mud on fire roads, beach accesses, and snowy conditions should not be a problem at all. Now...this all comes with some common sense. Such as trying to drop the vehicle into 12" deep mud holes, or really soft rutted out sand banks, or 2ft deep uncleared snow, all of which would warrant a vehicle with more ground clearance, and more capability off road.
But back to the OP's question, I do think that the 2011 should fit your needs, and while it may be a little "softer" of a vehicle, it should not be ruled out of your potential search.
__________________
Chandler
Official Slackmaster #24
  #5 (permalink)
Old 10-30-2011, 11:11 AM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
2011 Ford F-350
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 2011 & Newer Explorer forum.
__________________
John
2011 F-350 4x4 Lariat Ultimate, Oxford White / Pale Adobe 6.7L PSD 3.55 ELD / Gone but not forgotten.
2013 Ford Taurus SHO, Tuxedo Black / Black Leather
Moderators, Guidelines, and How They are Enforced / FTE Forum Guidelines
Currently truckless
  #6 (permalink)
Old 11-15-2011, 09:52 AM
nkenney nkenney is offline
nkenney is gaining momentum as a positive member of FTE.nkenney is gaining momentum as a positive member of FTE.
There is not that much offroad capability at all.
  #7 (permalink)
Old 11-16-2011, 06:10 AM
03 SVT VERT 03 SVT VERT is offline
03 SVT VERT is gaining momentum as a positive member of FTE.03 SVT VERT is gaining momentum as a positive member of FTE.
It has less ground clearance then the old explorer.
It has no low range transfer case.
It has open front and rear differentials.
Instead of a true center differential/transfer case, it has a PTO which connects to an electronically controlled clutch pack at the rear differential. It engages the clutches to drive the rear wheels when it detects slip, other wise it stays in FWD. It will also default to FWD if the clutch pack over-heats or senses a condition that could lead to damage.
While I would say it's better than the average CUV, it's definitely a less off-road capable vehicle than the previous explorer. Its off-road prowess basically comes from the computer's ability to modulate the brakes and rear clutch pack retroactively. In contrast, a true 4WD system is much more proactive.
  #8 (permalink)
Old 11-17-2011, 07:53 AM
tseekins's Avatar
tseekins tseekins is offline
2011 Ford F-150
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
Let us not forget that there is comparison between the current gen Explorer and it's predecessor. Only the name remains the same.
This is not a truck nor is it intended to be. The days of an Explorer built on a Ranger chassis are long gone. The Explorer slowly evolved over the years into what we have today.
I wouldn't consider this vehicle for any off road use. In my opinion, it's strictly intended for on road service in all weather conditions.
__________________
Tim
SCPO United States Coast Guard Retired
2011 F-150 XLT 4x4 Ecoboost
2010 Ford Focus
2004 Expedition XLT 4x2
FTE Guidelines
  #9 (permalink)
Old 11-20-2011, 08:26 AM
Encho's Avatar
Encho Encho is offline
Encho is a splendid one to beholdEncho is a splendid one to beholdEncho is a splendid one to beholdEncho is a splendid one to beholdEncho is a splendid one to beholdEncho is a splendid one to beholdEncho is a splendid one to behold
I wouldn't use this truck off-road either, but if there is the need, i bet the truck can get you out of a hurry. I've seen all kind of claims without any real data to back them up, so those are OPINIONS, not FACTS. Until the truck has been properly tested and compared i would not make any claims about it. Of course, mechanical drivelines for the driveline will be more dependable than hidraulics and clutchs, yet the old Explorer wasn't all that much as an off-roader either. The new one just got better at what has been the task of this model for a while, an all-weather transport, yet it has the capability to help itself out of some snow/sand in a hurry, not a daily basis off-roader.
__________________
1993 Special Edition Bronco: 5.0lt V8, E4OD Auto, MM Supreme manual hub lockers and a sweet roof tent, ROTW in 2/9/09
My Write-ups: Ford Steering Box Rebuild / Ford Front End Rebuild and auto hubs replacement / Ford Rear Drum Brakes / Ford E4OD Cooler & Shift Kit mods, drain-refill procedures
Quote:
Originally Posted by kowboy1
Find someone else to take your third world anger out on...
Yep, but I'm the one with issues here.
  #10 (permalink)
Old 11-20-2011, 09:00 AM
Here's one off-road test of the new Explorer:
http://youtu.be/135d_imepQU
Doesn't take much to get it stuck.
  #11 (permalink)
Old 11-20-2011, 09:47 AM
Encho's Avatar
I wouldn't consider that stuck, he just rolled back and off he went, also, those tires didn't help at all, yet the video shows how that truck is no off-roader.
__________________
  #12 (permalink)
Old 11-20-2011, 12:04 PM
tseekins's Avatar
2011 Ford F-150
Nice find on the video. He makes my point for me. Keep this thing on road in all weather conditions and you'll likely be fine.
__________________
Tim
2010 Ford Focus
FTE Guidelines
  #13 (permalink)
Old 11-26-2011, 05:51 PM
BIGKEN's Avatar
BIGKEN BIGKEN is offline
So Little To Say!!!
BIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputation
Encho made a good point...that wasn't stuck...and...with the proper tires and pedal modulation...there would have been no issue.
Ford didn't build this vehicle to be an Off Roader...it was built for the situations the vast majority of purchasers will experience. The Explorer hasn't really been a capable off roader since the redesign for the '02 model year. Of course...real 4X4 did help...but...the vast majority of drivers very rarely used it.
Ford wasn't looking to fill a niche...it was trying to make a vehicle that would appeal to the masses...and...produce profits for the company...and share holders. After all...that's what it's really all about.
__________________
Member of the Massachusetts Chapter and Number One Winter Hater!!!
Illegitimi non carborundum!!!
  #14 (permalink)
Old 01-31-2012, 02:42 AM
dundonrl dundonrl is online now
dundonrl is starting off with a positive reputation.
Quote:
my 01 Explorer was ok in the mud, I almost had to use the winch to get me out of this mud hole..
Click the image to open in full size.
  #15 (permalink)
Old 02-02-2012, 02:10 AM
640 CI Aluminum FORD 640 CI Aluminum FORD is offline
2011 Ford F-150
640 CI Aluminum FORD has a very good reputation on FTE.640 CI Aluminum FORD has a very good reputation on FTE.640 CI Aluminum FORD has a very good reputation on FTE.640 CI Aluminum FORD has a very good reputation on FTE.
Either way this is most likely a situation that would have stopped a 2011+ Explorer dead in its tracks.
Tags
2011, 40, 4x4, awd, capability, explorer, exporer, ford, forums, no, offroad, real, road, selector, sohc, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
