Max tow package vs regular tow package?? - Page 2 - Ford Truck Enthusiasts Forums
Old 03-17-2011, 11:24 PM
blueovelboy's Avatar
blueovelboy blueovelboy is offline
blueovelboy has a very good reputation on FTE.blueovelboy has a very good reputation on FTE.blueovelboy has a very good reputation on FTE.blueovelboy has a very good reputation on FTE.
i see this has made the rounds and is posted in all the truck forums?
Old 10-11-2013, 06:35 AM
slwry66 slwry66 is offline
slwry66 is starting off with a positive reputation.
I have a 2011 5 liter regular cab long bed with 3.31 gears that will be replaced with 3.73. I want to start a 28 ft. trailer . I picked up the tranny cooler, t.b.c. and the correct 7 plug trailer harness and fuses. My question is will my radiator be ok or do I need a bigger one? I've read in different articles that ford didn't really make different towing radiators. Is this true? I noticed in the post from N578MD that the 5 liter was not listed.
Old 10-11-2013, 07:57 AM
meborder's Avatar
meborder meborder is online now
meborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant future
welcome to the forum! Glad to see the search function turned up a thread you found useful.
As listed earlier in this thread, the ONLY upgraded radiator comes the MAX tow package and i don't think the MAX tow option was ever available with the 5.0L engine.
For what you are pulling, i doubt very much that you would need an upgrade. Cooling doesn't appear to become a problem until you start towing over 9k lbs or so, at least from what i've seen on this forum.
Just for the sake of asking, why the gearing change?
are you towing more than 8,000 lbs?
did you find the 3.31's inadequate?
just curious, as there are a ton of threads on here about gearing.
Old 10-11-2013, 05:48 PM
everyone tells me that the 3.31 is not the best for towing. With the trailer loaded its close to 8000#
Old 10-11-2013, 07:33 PM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Quote:
Everyone who's telling you that hasn't driven a truck with the 6R80 transmission. Going from 3.31 to 3.73 will only gain ~12% more torque in any given gear. Do you really think 12% is worth the expense? I sure wouldn't.
If your engine gets too hot your truck will reduce power; if this happens frequently while towing then I would recommend getting the upgraded radiator. If not I wouldn't bother.
Old 10-11-2013, 07:42 PM
D8chumley's Avatar
D8chumley D8chumley is offline
Resident smarta$$
D8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud of
Quote:
Originally Posted by n578md View Post
TRAILER TOW PACKAGE (535)
Side Mirrors, Manual Telescoping Trailer Tow w/Power Glass (includes
heat, memory, turn signal & puddle lamps & Chrome Skull Caps)[/COLOR][/SIZE]
Nobody else caught this?
Old 10-11-2013, 09:57 PM
meborder's Avatar
if you haven't already made the change, i would at least try it and see how you feel about it.
According to Ford, your maximum towing is around 8000 lbs, depending on cab configuration.
http://www.fleet.ford.com/resources/...ng%20Guide.pdf
You will be close to the max recommended for your gearing, but changing to 3.73's only gets you another 1400 lbs or so ... as Tom said above, there's not a lot of gain from going from one gear set to the other.
i'd give it a try before you dump a grand into a gear change, you may not feel the need.
Just be realistic.... it is going to shift, and it is going to "feel" heavy. but let the trans do it's thing and use the skinny pedal to decide how fast you want to go, and how quickly you want to get up to speed. Changing to 3.73's isn't likely going to make it shift a whole lot less, to be honest.
Old 10-13-2013, 05:20 PM
thanks for all the info guys. I'll try it like it is and then decide if I need a change.
Old 10-15-2013, 07:46 PM
seuadr seuadr is offline
seuadr has a good reputation on FTE.seuadr has a good reputation on FTE.
Quote:
if you are talking about the current coyote 5.0L you can get the max tow with the 8 foot bed or if you get the heavy duty payload package you automatically get the max tow package.
At least that is how it has been on the build and price tool and as listed in the order guide.
Old 10-15-2013, 08:49 PM
meborder's Avatar
incorrect.
5.0 v8 and 8' box with 3.73's gets you either 3.7L v6 or 4x4 with e-locker
or
5.0 v8 and 8' box with 3.73 LS gets you Max Payload, but no Max tow. (but 10,000 lbs towing with the regular towing package)
under no configuration can Max tow be had with the 5.0 v8. Max tow is reserved exclusively for 6.2 v8 or ecoboost.
i don't have the order guide at my disposal, but on their towing capacities page:
2013 Ford F-150 | View Towing Specifications | Ford.com
you will not see the "*" indicating Max tow on any configuration available with the 5.0 v8.....
Old 10-16-2013, 12:46 PM
incorrect.
or
i stand corrected - for some reason i was thinking that the max payload package automatically included the max tow package.
Old 10-16-2013, 05:42 PM
meborder's Avatar
With the Ecoboost, it does.
oddly enough, though, Max Payload is not available with the 6.2 v8.
if one opts for the 3.73LS gears, you get:
max payload with 5.0 v8
max tow with 6.2 v8
max tow and max payload with ecoboost.
or, 3.7L v6 (for regular cab and extended cab short box, and crew cab 4x2)
  #28
Old 10-16-2013, 06:24 PM
would be interesting to see a super cab long box max payload 3.7L
it is pretty much what i want, since i want the payload to haul a camper once in a while but 90% of the time will be hauling with little to nothing in the back.
2013 F150 Ecoboost Max Tow question jokerb19 2009 - 2014 F150 29 07-15-2016 07:05 PM
F150 Max Tow Package includes? dooger54 Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 5 05-25-2016 09:40 PM
Max Tow V.S. Regular Tow Package? the_auto_tech 2009 - 2014 F150 16 02-27-2015 09:08 PM
Question about 5.0 and tow package. zontral 5.0L Coyote 6 08-13-2014 08:59 PM
Max Tow and Max Payload meborder 2009 - 2014 F150 4 03-09-2012 10:34 PM
Tags
2009, 2011, bumper, f150, ford, fx4, group, hitch, lariat, max, mirrors, package, picture, rear, tow, trailer, upgraded, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
