Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 03-11-2011, 10:10 AM
developer developer is offline
Garage is empty, add now
developer is starting off with a positive reputation.
Help! Wiper switch - Different Versions???
Hi All.
This is weird.
The multi-switch harness plug started to go on my 99 Expy, you know, melting from too much current, and the turn signal wasn't working right.
So, I pulled it all apart and ordered a new switch. I added the headlight relay and I repaired both the harness and plug with epoxy and harness wrap. All good.
I put in the new switch and the wipers do not function properly; however, they do with the old switch. I spoke to the auto parts place and they said it must be defective, so they sent another. It does the same thing.
I put an ohm meter on the plugs and it seems as if the way it determines the mode for the wipers is to vary the resistance across 4 terminals.
The values on the replacement switch (only measured 1) is completely different than on the original one.
I am told and verified by the switch label, that the multi-switch is the same for the Expy and Excursion (label had 2000-01 Excursion). When I mentioned that to the parts people they said it was all the same part.
I think they may look the same, but electrically they appear very different.
When I turn the replacement switch on for wipers, they won't come on in delay and when they are set to full on and then off, they won't turn off until the key is switched off. When the key goes back on, they stay off, but still function in this weird way.
I'm thinking that Ford changed the way they did this and the replacement part isn't correct.
Can anyone shed some light on this?
As usual, thanks in advance!
  #2 (permalink)
Old 03-11-2011, 10:13 AM
(Sorry - I clicked the wrong year forum)
Tags
1973, 2000, 2005, buy, expedition, f150, ford, harness, multi, multiswitch, plug, ranchero, signal, switch, turn, wiper, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
