speedometer calibration - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 03-11-2011, 09:21 AM
quesey's Avatar
quesey quesey is online now
quesey is gaining momentum as a positive member of FTE.
hello i dont get over here much as the ranger just don't give many problem's.but my speedometer is off and i was wondering if theres a way to calibrate it.it's a 95 ranger with a 5 speed and it has the sensor on the rearend so i don't think i can just change the gear in the trans.
thanks john
Old 03-11-2011, 12:37 PM
ranger pat's Avatar
ranger pat ranger pat is offline
ranger pat has a good reputation on FTE.ranger pat has a good reputation on FTE.
I think the answer is you have to take it to a dealer or somewhere to have the computer reflashed. I take it the you do not have the stock rear and or tires anymore?
Old 03-11-2011, 02:05 PM
tomw tomw is offline
tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.
If the speedometer is electronic, you have a limited number of 're-programmings' that you can do before you have to buy a new head. There is a process to change the embedded ratio and tire size 'factor' [I think...] but I don't know it.
Did you search here and on the web?
tom
Old 03-11-2011, 06:08 PM
quesey's Avatar
still has stock size tires and gears.3.73 i beleave and i looked online and here first.i know theres a way on my 96 f350 but not sure how to on it.
thanks for the helps guys.i'll do some more searching around
Old 03-12-2011, 06:39 AM
greenpus greenpus is offline
greenpus is starting off with a positive reputation.
Quote:
thanks john
how far off is it? Is it off throughout the entire speed range or just when you get about 40ish? I know some people remove the cover on the speedo and pull the needle and put it on wrong which may throw off the accuracy for the entire range of speed.
If it's off by a little, I'd put up with it or take it to the dealer and ask them to recalibrate the computer for the speed. It's strange you still have the same tire size and it's off. Other option is to buy a TruSpeed from SuperLift. It's a module you install and it fixes the speedo from being off.
Old 09-22-2013, 04:07 PM
dbak dbak is offline
dbak is starting off with a positive reputation.
i replaced my odometer gear and did not realize that it through my speedometer off and need to know how to recalibrate dbak
Old 09-23-2013, 08:21 PM
reddog99 reddog99 is offline
reddog99 is starting off with a positive reputation.
thanks john
I think that the sensor in the rear end is just for the ABS system.
Old 09-24-2013, 10:21 AM
dbak, read my post. If you do NOT have a speedometer cable from the tailhousing of the transmission, it uses a speed sensor, likely mounted on the differential housing. In that case, the speedo assembly itself can be electronically 'adjusted' to compensate for changes in ratios & wheel size, etc. As I noted there is a limited number of re-calibrations that are possible, and you may or may not be able to compensate for what ever changes you've made.
I am pretty sure the dealers are the only ones that can do the procedure, as they can also set the odometer reading when they have to replace a faulty unit. If it were simple, then all used cars would have low mileage, so it is kept proprietary.
tom
Old 09-24-2013, 08:19 PM
ranger speedo recalibration
thanks for your input Tom, buti just cant afford a dealer especially one this old and i am dumb enough to enjoy fixing it myself
Old 11-02-2013, 08:38 AM
thanks guys' i think i got it working correctly
hypertech speedometer calibrator ?? DanielT28 1999 - 2003 7.3L Power Stroke Diesel 6 12-12-2015 01:33 PM
Speedometer calibration tool? DanielT28 1999 - 2003 7.3L Power Stroke Diesel 3 08-08-2015 06:44 AM
Auto Enginuity & calibrating speedometer UP_There 1999 - 2003 7.3L Power Stroke Diesel 24 08-12-2014 09:13 PM
Speedometer calibration - now what... jpcjguy Excursion - King of SUVs 5 12-16-2010 08:25 PM
I Need Gear/Speedometer Help peterbilttrucker 1973 - 1979 F-100 & Larger F-Series Trucks 27 05-03-2009 02:01 PM
Tags
calibrate, calibration, calibrator, f150, f250, ford, modular, power, ranger, recalibration, recalibrator, series, speed, speedometer, sw, truck, tsb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
