Race track trim question
Old 03-11-2011, 09:13 AM
Roelito78's Avatar
Roelito78
Roelito78 is offline
One more question for all dentside gurus. I am installling new race track trim on my dent and ran across a problem. The new trim that attaches to the bed side has 4 clips that attatch above the wheel well that include 4 rubber pieces of some sort. I have no idea where these pieces go attached. I imagine they are suppose to attach between the molding and the clip but not sure. I installed the trim piece on the drivers bed side and left the rubber pieces off and now have a gap between the trim and bed. Any suggestions or ideas? Thanks guys and gals!
Old 03-11-2011, 02:03 PM
650's Avatar
650
650 is offline
Well you cold look at the LMC catalog to see what goes where if thatd help you. Also you are probably going to have to take off the driver side again because the rubbers are probably there so the molding doesn`t beat off your paint and rust.
Old 03-11-2011, 02:25 PM
ranger429's Avatar
ranger429
ranger429 is offline
Are they round little rubber pieces with a hole in the middle? If so they go between the body and trim clip.
Old 03-11-2011, 02:28 PM
Roelito78's Avatar
Roelito78
Ranger,
They are squared with a small slit in between them if that helps. Wish they were round probably would be easier to figure out how they are to be installed
Old 03-11-2011, 03:00 PM
CalebJns's Avatar
CalebJns
CalebJns is offline
A pic would be helpful...but are they square on top, and tapered downward?
Quick question...how do you safely remove the trim...removal for reuse in the future?
Old 03-11-2011, 08:13 PM
ranger429's Avatar
ranger429
On the original clips they used a small disc type piece of rubber that went over the stud of the clip. The replacement could be what you speak of. Post a picture of it.
The lower trim has some clips that are retained with nuts and some of the other clips just push thru a hole in the body.
Old 03-12-2011, 05:44 AM
Roelito78's Avatar
Roelito78
Ranger,
I will try to take some pics today, if anyone else has any feedback let me know. Thanks
Old 03-12-2011, 08:13 PM
Roelito78's Avatar
Roelito78
Ranger,
Here are a few photos taken, see if this helps. Thanks
Old 03-12-2011, 08:57 PM
ranger429's Avatar
ranger429
I have never seen those with any of the NOS trim I bought for my Bronco. I can tell you they are not used with the mounting clips themselves.
Was the package sealed?
Old 03-12-2011, 09:13 PM
Roelito78's Avatar
Roelito78
Ranger,
Packages were sealed and they each included the clip and rubber piece. When I installed the clips only with the trim there is a gap in between the trim piece and the body of the truck. I understand that there are 4 clips above the wheel well that just clip in with no nuts to screw due to access limitations. I'm really confused now
Old 03-12-2011, 09:15 PM
ranger429's Avatar
ranger429
Was this trim NOS ford stuff or aftermarket? I'm guessing this is aftermarket trim. Looking at that piece of rubber it looks as though it may fit inside the trim and act as a cushion between trim and paint.
That is correct on the "no nut" clip. You cannot access the backside so they are a push in clip. The others use a nut on the backside.
Old 03-12-2011, 09:26 PM
Roelito78's Avatar
Roelito78
Ranger,
The clips came from Dennis Carpenter. What you are saying makes lots of sense the only thing that confuses me is the gap that is still left behind. Right now there is a gap and the trim appears a bit loose as if the clips wiggle when I touch the trim. All other clips and nuts are nice and tight but the 4 clips on the wheel well area are somewhat loose.
Old 03-12-2011, 09:40 PM
ranger429's Avatar
ranger429
Did you try putting the piece of rubber behind the clip on the inside of the trim? I'm guessing that that will push the trim out to far from the body.
Don't know what else to tell ya. Call DC and see what they say. Originally there was no rubber used at all in the mounting of the moulding.
Old 03-12-2011, 09:45 PM
Roelito78's Avatar
Roelito78
Thanks anyway Ranger, I appreciate you sharing your thoughts and ideas! Have a good one
Old 10-08-2023, 01:54 PM
FordGirl!'s Avatar
FordGirl!
FordGirl! is offline
Did you ever find out how that rubber piece was supposed to be installed?
I'm doing mine right now and I'm scratching my head on how it is supposed to be installed. I don't recall having any rubber piece in place when I removed my trim. Maybe it rotted away? Maybe it doesn't get used for certain models?
Thanks for any help you can provide
Quick Reply: Race track trim question
