egr delete should I do it - Ford Truck Enthusiasts Forums
Old 03-11-2011, 07:42 AM
carcus carcus is offline
carcus is starting off with a positive reputation.
I have a 2006 6.0 with low milage around 70 000miles, truck is running good no problems, I live up in manitoba canada, and I have a diesel mechanic that will work for 40$/hr, its hard for me to spend money when there is nothing wrong with my truck but I do want this truck to last, what is the advantage to removing the egr and are there any disadvantages and should I have it done or leave it alone? The mechanic also mentioned he would install a flashtuner? I guess to tell the computer that the egr is still there? Thanks for any advice...Jason
Old 03-11-2011, 07:48 AM
tex25025's Avatar
tex25025 tex25025 is offline
tex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud of
Quote:
I'm on in the minority that believes that in of itself the EGR system doesn't need to be deleted or bypassed. Now I don't know what your emission laws are like for you yanks up there, but I would make sure that you consider that and also make sure that if you do have emission testing in certain areas that it still isn't illegal for you to remove the EGR system in areas that do not have testing. That's a wrong connection that people down here make and it has cost some people quite a bit of change.
For a 2006, you will need to have a custom tuner write a tune that shuts off the EGR system entirely and tells the computer not to go looking for any input signals. You don't have to have any increase of HP/TQ output unless you want to.
Find out your laws first to see if you should do it, after that think about if you want to do it since you don't have anything mechanically wrong to led you to that decision.
Old 03-11-2011, 08:30 AM
GIGGER's Avatar
GIGGER GIGGER is online now
Posting Legend
GIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputation
Maybe spend your money on studs or coolant filter..........dont go asking for problems.
Old 03-11-2011, 09:02 AM
Elvis40's Avatar
Elvis40 Elvis40 is offline
Elvis40 is starting off with a positive reputation.
personally, i wouldn't force it. A year after I bought mine my oil cooler went and i did both @ the same time.
Although it runs a little better. It's not this "amazing fix" that solves all the worlds problems. Keep an eye on the EGR valve, wait until you have to go in there for something else.
69cj's Avatar
69cj 69cj is offline
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
Keep your oil cooler and cooling system healthy and ther is no reason to delete the egr cooler.
Old 03-11-2011, 09:15 AM
horn's Avatar
horn horn is offline
horn is starting off with a positive reputation.
I was serious thinking about deleting my egr, but after reading several forums I'm having my doubts. Question: Can I just use a tuner to bypass the egr? Also if I decide not to delete the egr or by a tuner, should I take the egr and clean it every once in a while. Thanks for the help.
Old 03-11-2011, 09:24 AM
tex25025's Avatar
Quote:
You can shut off the valve from opening and closing with just a tuner, but there are the fluke instances where the person doing the tuning may not have tuned it correctly and sometimes there are still issues.
I will say this, Matt at Spartan anecdotally found out that more people claim to have better MPGs with the EGR kept on then turned off. Now there are a lot of factors that go into MPG calculations, so take it for what it's worth, but that was one reason that towards the end of his SCT tuning days, he left the EGR on unless specifically told otherwise.
Old 03-11-2011, 07:41 PM
Striderwv's Avatar
Striderwv Striderwv is offline
Striderwv is gaining momentum as a positive member of FTE.
IMHO I would check my ect and eot differential. If it is ok, yur oil and egr cooler should be fine. If not, then you can decide to delete or replace the egr cooler while yur replacing the oil cooler. I'd spend the money on a gauge or gauges to measure at a minimum ect, eot, boost, fuel pressure and egts. They will keep an eye on things so the truck will last and let you know what and when you need to fix something.
Old 03-12-2011, 12:27 AM
Jr.Luke08 Jr.Luke08 is offline
Jr.Luke08 is starting off with a positive reputation.
I did not want to do it but my temps spread to the 15 mark and then all my coolant disappeared. So I went ahead and pulled the plug and did an EGR delete along with a new coolant filter. But I first bought the Insight and the coolant filter in hopes of preventing this mess.
Old 03-12-2011, 04:24 AM
Thanks for all the responses, probably leave it alone for now, I thought this may be good for the engine? Just wan't the truck to last
Old 03-12-2011, 07:27 AM
GIGGER's Avatar
Posting Legend
It will last, maintenance is the key with Ford filters & Ford cetane booster.
Old 03-12-2011, 08:38 AM
What is this, "Ford cetane booster".
Old 03-12-2011, 08:48 AM
smokersteve's Avatar
smokersteve smokersteve is offline
smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.
The egr system leaves build up in the intake. Cleaning that will also do allot of good
Old 03-12-2011, 11:13 AM
GIGGER's Avatar
Posting Legend
Because we have to buy ULSD (ultra low sulpher diesel) fuel, it helps to add "cetane booster" every time we fill up (about 5 onces), We buy it by the gallon at the Ford store. Keeps your motor happy.
0401 EGR question BRONC-OH 1997 - 2003 F150 7 06-12-2016 01:53 PM
EGR line replacement Chezzer Aerostar 7 05-06-2012 12:12 PM
EGR delete on 04..how hard is it... jamie7375 6.0L Power Stroke Diesel 4 11-29-2009 12:14 PM
Swapping a 5.4L non EGR with 5.4L EGR engine wall77 1999 to 2016 Super Duty 4 11-12-2009 07:36 AM
EGR valve ? 89broncobob 1978 - 1996 Big Bronco 3 07-21-2003 08:24 AM
Tags
2006, advantages, bypass, cooler, delete, duty, egr, f250, f350, ford, happy, oil, people, replacing, super, tuner
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
