Information on 1976 Dana 60
Hello Guys
I am Corey and I have recently purchased a 1976 F250 4wd High boy with a steel dash (Canadian spec???)
Unfortunately its been built with the steering wheel on the wrong side of the truck.
It is fitted with a front Dana 44 with twin piston disc brakes, however the centre of the housing has been cracked. It has been repaired and braced sometime in the distant past. Im not sure that I would like to use this axle.
I am looking at my options for upgrading the front axle. I was looking at using the Dana 60. Apparently I need one out of a 74 to 76 crew cab??? for it to bolt in.
Now what makes this project difficult is that I am in Australia, hence the steering wheel on the right side. They are a pretty rare truck over here. How difficult is it to find a dana 60 front axle or can one be built to fit the 76 high boy chassis? I found one on the west coast of usa but the freight to get it to the west coast ,where i have a company who containers stuff to australia kills the deal.
Is it easy to find something on the west coast, washington area?
Thanks
Corey
Thanks
Corey
I am pretty sure you won't find one from a 74-76 crew,because I don't think they exsist.However I may be wrong.
I do think that you can use one from a 78/79 snow fighter or F350.I believe there are other years that will fit,and I'm sure someone more knowledgable will chim in eventually to help answer your question.
Hello
Thanks very much for the information. I had been told the Dana 44 was a weak item in this truck. I would much prefer to keep the 44 as there is already enough work being done to fit up a cummins engine and sorting the bodywork.
The truck did come from a very isolated country town with rough dirt roads and was used by an opal miner. This is probably what lead to the centre being cracked.
This is not the only broken item. Both front leaf packs had broken springs and the right rear had the back eye broken off the end.
Thanks very much for the advice.
Corey
Corey
zerfetzen
114
07-28-2022 03:38 AM
84XLF150
11-26-2015 01:18 PM
Xauterus
15
01-23-2012 10:38 PM
zak8tac
24
12-14-2009 03:36 PM
