2011 F350 5th Wheel Towing Capacity
I have searched dozens of forums and ford.com's website and I'm still confused. I just order a 2011 Ford F350 Crew Cab 4x4 SRW w/ factory 5th wheel prep kit. I'm going to purchase the 25K Reese Hitch and a 2011 Chaparral 355 RLTS 5th wheel (base weight = 10,465 and hitch weight = 1,970). Behind it, I'm going to tow a 5,500 lbs boat which sits on a tandem axle trailer with surge brakes.
How do I calculate what my towing capacity limit is?
https://www.ford-trucks.com/forums/1...-tow-geez.html
Stupid question time: At $50-60K each, why would you order before knowing the real numbers?
You are starting down a long and sometimes confusing path. About 9 months ago, I was in the same place, this forum was a great help.
Assuming your new 2011 is diesel and a short bed, you have the same set-up I have got. I have done extensive number crunching, the result of which is here.
The 'Tow Vehicle (empty, wet)' is right off the CAT Scale. With the in-truck payload (passengers, their stuff) and the hitch in the back, the truck weights in at 8,970 pounds, leaving 2,530 pounds (11,500 - 8,970 = 2,530) for pin weight (with no margins). Given the 20% norm for 5th wheel pin weight (20% of (trailer base weight + in-trailer payload)), and a 10% pin weight safety buffer, this puts the trailer's maximum weight at 11,385 pounds. Anything over that and the truck will be over its 11,500 pound GVWR.
Regarding the boat, I don't know. Presume it would count against GCVWR (23,500 pounds). Truck + fiver + boat < 23,500.
Steve
Steve
https://www.ford-trucks.com/forums/9...el-towing.html
Steve
dont forget to add in your tires max load rating x2 and subtract that number from your rear RAWR. If the ratings on your 2 rear tires is less then the GRAWR, then subtract that number from your RAWR. example is my rawr was 3800, my grawr is 7000, but my 2 rear tires max load=7280lbs....so 7000-3800=3200lbs.
Below is a snippet from Ford's website regarding the 2011 F350. If I'm readying it correctly, my 2011 Ford F350 Crew Cab Diesel can tow a 24,400 lbs 5th wheel, correct?
The new Super Duty® has impressive numbers to back its claim of being best-in-class in both towing and payload.* Maximum 16,000 lbs. conventional towing. Maximum 24,400 lbs. 5th-wheel towing. Maximum 6,520 lbs. payload. These are big numbers that’ll impact your bottom line for the better when the workday is done.
*Class is full-size pickups over 8,500 lbs. GVWR.
johnbro27
Fifth Wheel & Gooseneck RV Towing
10-05-2016 08:03 PM
Boomer23059
07-07-2011 03:09 PM
