Driver Blend Door Actuator
I replaced my passenger side blend door actuator a while back and now my driver side one has begun making noise every once in awhile. No temperature variations yet, but I imagine it is only a matter of time until it fails like my passenger side one did. My question is has anyone replaced it themselves? I realize this is a dash removal so I'm curious if anyone else has undertaken that task in their garage yet.
I was going to replace both of my actuators because I procrastinated and didn't get it done prior to 36k miles. But when I looked at the service manual, the fix requires opening the A/C lines and then recharging that system. And I don't have the equipment or knowledge to do that. It's also around a 9 hour job, so I think I shall live with cold coming out of the port vent and heat coming out of the starboard one.
After a $700 estimate, I took a look under the dash myself and found the control motor (actuator) attached right to the side of the plenum (im assuming) just to the right of the gas pedal. looks a bit tight, but certainly the dash doesn't need to be taken apart to get to it. Seriously? $700, they can say that with a straight face, it would probably take the dealer less than an hour to replace it. The part probably costs less then $50, they should be ashamed of themselves for ripping people off like that. All of that being said, is this the same control mother above the gas pedal, to the right, that others have described removing? Looks like just three bolts holding it in place, do I just remove and replace? anything to watch out for? I bought a chiltons guide but doesn't have too much info on the replacement. if anyone has a guide from a service manual that would be helpful.
Thanks
Thanks
Thanks
Thanks
I'm guessing the part you're looking at is not what you think it is. There have been a handful of do-it-yourselfers here that have changed the drivers side actuator and by all accounts it IS a quite involved process taking far more than an hour.
boatnfish
01-26-2024 06:58 PM
rexpedition99
11-29-2019 07:18 PM
Sooner in Kansas
11-19-2015 10:57 AM
