Transmission Flash? - Ford Truck Enthusiasts Forums
Transmission Flash?
Old 03-10-2011, 07:28 PM
efx4's Avatar
efx4 efx4 is offline
efx4 is gaining momentum as a positive member of FTE.efx4 is gaining momentum as a positive member of FTE.
Transmission Flash?
I love my truck, but not this transmission shift hesitation. Before I contact my service dept. about this, I would like to know if anyone has had a re-flash done (if there is one), and if so, what were the results.
Old 03-10-2011, 11:07 PM
Bronc1 Bronc1 is offline
Bronc1 is starting off with a positive reputation.
I have an 11' w/5.0L and mine hesitates between 1st and 2nd it goes to the dealer next week.
Old 03-11-2011, 09:31 AM
Turbodogg's Avatar
Turbodogg Turbodogg is offline
Turbodogg is starting off with a positive reputation.
My 09 had that same hesitation between 1st and 2nd when I first bought it, but has since gone away. Someone on here told me that the trans has to learn your driving habits and then it adjusts itself accordingly.
But, efx4, you have had your truck for some time now. That may not be the case with your truck
Old 03-11-2011, 06:11 PM
efx4's Avatar
The shift hesitation happens when in any gear, but it's mostly when I'm cruising along and I need to accelerate quickly and the trans slowly goes down every gear and then after about 3 or 4 seconds, it finally moves. I have a lead foot, so the pcm should have learned my ways after 4 months. It's tough to pass or merge because I need to give myself more then a few seconds extra for the truck to respond. I'm just going to call the dealer and take it from there.
Overdrive light flashing on 2000 F450 7.3 Ziob 1999 to 2016 Super Duty 10 06-12-2014 08:31 AM
Transmission question Blue Oval 105 1987 - 1996 F150 & Larger F-Series Trucks 5 02-22-2014 08:54 PM
Overdrive Light Flash azpowerstroke 1994.5 - 1997 7.3L Power Stroke Diesel 6 05-07-2012 11:30 AM
Trans O/D light flashing dddenio Excursion - King of SUVs 11 10-06-2009 02:21 AM
1993 Ford Ranger ABS Codes sdlinden Ranger & B-Series 3 08-11-2003 12:01 PM
Tags
f150, flash, ford, fusion, glash, sport, tranny, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
