272 performance rebuild help!
I have a v8 272 y block in my 56 f100 with a 2 barrel carb. I am wanting to rebuild it to get some more horses out of it..hopefully more than 200 and use it as daily/project car. any ideas on inatke manifold, carb, roller rockers, cam...etc. I really appreciate the help. I am looking for ideas such as bolt ons and internal work.
Check out the Y block forum for more help. In the meantime go to www.ford-y-block.com and www.y-blocksforever.com JIM
Oh,and wellcome .
Oh,and wellcome .
You're really in the wrong forum for this.....
You might be better off posting in the Y-block forum...... Y-Block V8 (239, 272, 292, 312, 317, 341, 368) - Ford Truck Enthusiasts Forums
Now having said that, go to FORD Y
and Y-BlocksForever Forum
and you'll find all the Y-block "stuff" you'll ever want to know!
Cheers,
Rick
I guess you can see we don't make you wait around here for information L.O.L.
What will be come know as the “Wayne’s dissenting opinion” reply;
I think it would be fair to say that the Y block has certain built in performance limitations that for the most part can be overcome with time and money, to eventually arrive at a point of un-drivability and the power output of a 302 with a four barrel!
Bore it out to 292. Find a couple heads with bigger valves, the 272 trucks came with small valves but the T-birds had big valves. Rebuild engine and heads. Get a 4bbl intake and new 4bbl carb, I got my carb from Summit. Put on dual exhaust. That should get you in the ball park of 200 hp. Beyond that you can spend a lot a money. Cost $2500-3000 IMHO
The majority of the 272’s can be bored to the standard 292 bore size (0.125” over) but there are those rare few that have core shift or block imperfections that prevents this. Sonic checking the block before boring would be the only way of knowing this for sure and preventing some possible headaches later. Even blocks with heavy core shift can occasionally be salvaged by offset boring using the sonic test data.
'57 Ford F100 Nut
08-17-2014 07:36 PM
Y-block
10-08-2013 06:36 PM
prof10000
02-18-2008 09:39 PM
