Please help..Transmission stuck 2004 Super duty
Hi: I am new to this forum so please forgive me if this has been dealt with before. My 2004 F250 super duty crew cab is stuck in park. Every once in a while it will move to drive, but once stopped and in put in park, its stuck. Its an Automatic transmission
Need help and advise please.
My email is
uacg@sonic.net
Thank You
Tom
My email is
uacg@sonic.net
Thank You
Tom
What Skip and I are both getting at is the Brake-Shift interlock. You have to depress the brake pedal to shift out of Park. You probably knew that, but one never knows. The circuit may also not work right if you have a brake lamp out. It also may not work if you have a bad brake switch.
When it won't shift out of Park, you can try this. Turn engine off. Depress parking brake. Turn key to the Off position (steering wheel will still turn), and then shift the transmission to the Neutral position. Then start the engine in Neutral. That should get you home so that you can figure out what is wrong.
I'm betting brake switch, since it is intermittent.
Can you tell me where these are located?
Thank You
Tom
PS I just went outside and tried it again. It has not run since yesterday. I turned the key to the first position, stepped on the brake and it worked fine 10 straight times. So now I guess the engine must be warm??????
Trust just went out the door
Thank You
Tom
Thank You
Tom
Thank You
Tom
https://www.ford-trucks.com/forums/1...r-shifter.html
I have an 04 f250 and had the same problem for about a year. I just got used to reaching under the dash and lifting up on the brake/interlock switch to release the shifter. It would only do it periodically at first. but then it did it only when the weather was cold. then it did it constantly. I finally stopped being lazy and fixed it. I was cheap and pulled apart the component, bent the contacts a little and re-installed it. Works every time now The contacts wear and the gap becomes to great for the movement from the brake pedal to force them into contact.
It's located right where the brake pedal meets with the shaft that comes through the firewall from the brake cylinder. Right at the joint where there is a steel pin connecting the shaft and brake pedal. If you can't move the shifter from park, reach down and lift up on it. It should immediately release the shifter. There will be a painted yellow metal cotter pin covered by a yellow plastic cover to prevent it from coming loose. When you remove the steel pin the switch will fall off. It takes a bit of fiddling with to get the switch out and when you go to re-install it. But it's not hard to figure out(just the angle, and working under the dash that makes it a PITA) The componet case is just two plastic halves held together by 4 small plastic snaps around the outside of the case along the seam. I used my pocket knife to release the clips. Once open you will see two sets of contacts. One set for the brake lights, one for the shifter lock release. I just bent the long copper contacts just enough to close the gap a bit.
When you open it up and see what it contains... you wonder why they charge so much for it.
Specialtools
Vendor Specials, Discounts, Product Announcements & Group Buys
07-06-2016 09:44 AM
fuzyface
1999 to 2016 Super Duty
05-23-2006 04:13 PM
