6.0 Transmission cooler install question
I'm in the middle of my 6.0 transmission cooler install and had quick question.
Does the direction of transmission fluid flow matter? In other words, does passenger side cooler connection need to go to the return line/drivers side connection go to the supply line or vise versa? I wouldn't think it would matter since it is a continuos loop, but I just wanted to check before I secure all my connections.
Right now, I have the drivers side going to the return line (line with the magnefine filter).
Thanks for the help!
In the process of installing, I needed to add a couple of 90 degree fittings. Nowhere locally stocked 1/2" 90 degree barbed fittings in brass, so I was forced to use plastic. It's rated to 480 degrees, but I'm still a bit skeptical. I did install the plastic fittings only on the return line, after the cooler, so theoretically it wouldn't see any spikes over 480. Any thoughts?
Those barb fitting will hold the pressure just fine, and if your temps ever get even close to 480 degrees you have other major issues to worry about besides that fitting. I might be concerned about it overtime as far is it possibly getting brittle. But they should be just fine until you can find some brass ones later on down the road.
I was thinking of getting these to replace the plastic ones with after the road trip. Anyone have a better source?
McMaster-Carr
Product #: 5670K19
McMaster-Carr
Product #: 5670K19
Where's a good place to get a 6.0 transmission cooler? I called a wrecking yard that told me they had two of them and a week a later I got a call saying they didn't have one after all. So I'm back on the hunt. Autozone keeps offering me a "heavy duty" generic cooler for about $60, so if the 6.0 costs too much more, I'll just go that route.
Some are lucky enough to find them on craigslist or a wrecking yard. They're few and far between there. If you want a used one quick at a discounted priced, ebay works well.
New ones can be had through partsguyed.com or Tousley Ford for around $350 IIRC.
I ended up going with the McMaster Carr version. They have very fast shipping and it's a solid one piece setup so there will be less restriction & fewer joints to worry about leaking in the long run.
I checked out my local Ace and they did have a 2 piece setup that works, but it was $45 for a few of them...
Yup straight from Mcmaster Carr. On my doorstep innless than 24 hours with ground shipping since I'm in CA. Shipping was $6 for that and a few other small things.
