Neutral safety switch
Just went through this, myself, bigcountry. If you've snapped off the NSS pin that's clamped to the steering shaft inside the column, which is kinda common as I'm finding out, you can still start the truck by reaching down and moving the switch nub to the left about a quarter of an inch. And then, order a new one for $12 from Dennis Carpenter (the exact same flimsy piece of tin will cost you $40 from LMC Truck).
If the NSS itself is bad and isn't responding to moving that nub manually, I don't think it'll start unless you rewire it to bypass it.
Can anybody confirm or correct this?
You might try moving the shifter in different locations while holding the key on the start position. Keep your foot on the brake in case its just out of adjusment as it may start in gear. Thats the way i did it, there was a no start in all gears , so i replaced it and that fixed it. I had mine up on jack stands too so there was no chance it would go though the garage wall if it started in gear. JIM
Or just unplug it and put in a jumper wire between the two wires that go to it. That way you can start it in any shifter position..........preferably "Park" That would be the safest way. If it starts with it jumpered, the switch is either bad or out of adjustment. You can check to see if the switch is actually bad by using an ohm meter and checking continuity. If you have continuity when the switch is activated manually, its just out of adjustment.
Vashon Islander
08-24-2014 03:36 AM
71Camper
06-25-2012 09:39 AM
