1996 heater core replacement - Ford Truck Enthusiasts Forums
Old 03-10-2011, 12:49 PM
perryau1996 perryau1996 is offline
perryau1996 is starting off with a positive reputation.
I have a 1996 with the 5.8. The heater core is leaking into the cab a little. I want to replace myself. I've read on this forum that some people say it's very easy. My mechanic says he will have to take the dash off. He says he will have to disharge the ac and it will be at least $350. Is the 96 different than previous years or should this be very easy?
Old 03-10-2011, 12:53 PM
zxwut?'s Avatar
zxwut? zxwut? is offline
zxwut? is gaining momentum as a positive member of FTE.zxwut? is gaining momentum as a positive member of FTE.
He's bull****ting you. I'd find a new mechanic, or if you are at all mechanically inclined, it is very easy to replace.
Old 03-10-2011, 12:58 PM
92 Black Nite's Avatar
92 Black Nite 92 Black Nite is offline
92 Black Nite is starting off with a positive reputation.
I just did my 92. Not hard to do. You pull out the glove box and it is behind it I did not have to remove the dash. Took me about 45 min. 1/4'' and 9/32 sockets did mine. You really should get a manual it will save you a bunch of money. While your at it you may want to replace the heater hoses.
Old 03-10-2011, 01:07 PM
Thanks for the reply....I've changed a core in the 91 i used to have. It was easy enough, just thought the 96 may be different since he said that. Thanks
Old 03-10-2011, 07:04 PM
Roger T. Pipe's Avatar
Roger T. Pipe Roger T. Pipe is offline
Roger T. Pipe is starting off with a positive reputation.
This is probably one of the easiest jobs to do on our gen trucks. Try to tackle this yourself-you'll find it pretty simple and you'll save yourself 350 beans to boot!
Roger
Old 03-10-2011, 11:42 PM
TorqueKing's Avatar
TorqueKing TorqueKing is offline
TorqueKing is gaining momentum as a positive member of FTE.
I'll join the concensus- it's so easy you'll think you did something wrong.
Your mechanic is a pirate. Shove his nose in that lie about discharging the AC. Ask him to show you exactly why. It'll be funny to see how he could possibly explain that. Then, do you neigbors a favor and hook him up on yelp.com with the review that he deserves so nobody else trusts him for anything.
There's a chance he's just simply mistaken, but without an apology I'd have fun with it. Be creative. I hate pirates.
Old 03-11-2011, 12:06 AM
cadillacmob's Avatar
cadillacmob cadillacmob is offline
cadillacmob is starting off with a positive reputation.
really that easy? In my 96 f150 my heat is not as hot as it should be. should i go ahead and do it myself?
Old 03-11-2011, 12:18 AM
drjoe171 drjoe171 is offline
drjoe171 is starting off with a positive reputation.
Quote:
Well?
Worst case is you don't get it finished before 'dark'.
What I would do, knowing my luck sometimes, is have a piece of
tubing to connect the heater hose lines together if I couldn't finish the job for some reason and still be able to drive it.
Heck, you might be able to plug the lines off with a couple spark plugs or something.
Old 03-11-2011, 03:40 AM
hav24wheel's Avatar
hav24wheel hav24wheel is online now
hav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputation
I did mine in under a half an hour start to finish. Easiest one I have ever done.
Old 03-11-2011, 04:32 AM
LCAM-01XA LCAM-01XA is offline
LCAM-01XA has a very good reputation on FTE.LCAM-01XA has a very good reputation on FTE.LCAM-01XA has a very good reputation on FTE.
I'd go for it, no reason to outsource it to a shop unless you feel uncomfortable with it for some reason, but even then it won't cost you no $350. About yer mechanic tho, I'd give him the benefit of the doubt and venture to say tis just he's never tackled that job on a truck of that body style - in many vehicles you do indeed have to either pull the dash apart or get the plenum out the front or both (at which point you gotta discharge the A/C and then recharge it after everything's back together), and if he primarily gets to work on such vehicles and trucks like yours rarely come in the shop I'd say tis fully possible he was giving ya the worst-case scenario based on his experience so far. Remember there are still lotsa honest mechanics, we ain't all out to get ya'll and yer hard-earned moneys...
Quote:
26 minutes is what I clocked myself at IIRC, still couldn't beat my OOBS non-A/C Chevy time, lol. But yah, you end up spending more time taking the hoses off the old core than it takes you to actually swap the cores.
Old 03-11-2011, 04:41 AM
hav24wheel's Avatar
Quote:
Before I did the core in my 94, the last one I did was in a 96 or so Dodge pickup.
That's one of those pita ones that half the dash has to come out. But I got away without splitting the heater box by cutting the heater hose tubes off the old core, and uncrimping the tubes on the new core, sliding the core into place, and recrimping the tubes back on after feeding them through the Firewall and into the core. Thank god for O ring sealed tubes. Saved a lot of time.
Old 03-11-2011, 07:58 AM
My mechanic ain't so bad after all. He thought I said 97 model when I talked to him on the phone. He said 96 is a peice of cake like the 91 I had. Thanks
Old 03-11-2011, 08:17 AM
Oh, one of those... I like that body style, but just about everywhere I hear they're a royal pain to work on... Thankfully I usually end up with driveline and suspension work on them and that's just regular annoyance, nothing too bad.
Quote:
See, I told ya he wasn't digging for gold in your pockets
No heater...wtf 73 ford guy 1987 - 1996 F150 & Larger F-Series Trucks 78 10-14-2013 01:17 AM
Heater Core Replacement JasonBrod 1997 - 2003 F150 5 10-04-2012 03:05 PM
1996 Changing Heater Core rlay302 1987 - 1996 F150 & Larger F-Series Trucks 5 02-12-2011 10:39 AM
Ah, the sweet smell of anti-freeze... ooooface Ranger & B-Series 11 11-23-2004 05:45 PM
E350 beast eats family income - rear heater core? cgilley 1968-2013 Full Size Vans 14 12-08-2003 09:32 PM
Tags
1996, 94, 96, core, f150, f250, f350, ford, forum, heater, pickup, replacememt, replacement, series, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Fordģ is a registered trademark of the Ford Motor Company.
