gas gauge not working???
could be a sunk float or the more likely problem is a bad sending unit. Check RockAuto Auto Parts and look up your vehicle. Look under fuel and air and then under fuel pump. You probably need the sending and float unit more than the fuel pumps themselves. Plenty of guys replace the entire float-pump-sender unit all at the same time.
While there is a little controversy about this... I have found the easiest way to replace these is by pulling your truck bed off and exposing the top of your fuel tanks. The only other way is to crawl under the truck and drop them down... I don't like this b/c too much crap falls down on your face and is kinda a pain. Plus you'd have to drop both fuel tanks... Engine hoists work good to pick the bed up... or you and 3 more friends...
I cut out my old bed bolts and removed my bed this last fall to do both tanks... It was easier to remove the old lock rings with the tank being held in place to the frame... Plus it gave me the chance to mig-weld a couple muffler holes, and run wiring for a 7-pin to the back bumper. Plus the new bolts I put in have antiseeze on them now so pulling the bed is a 20 min deal now...
a ayala
04-12-2010 11:54 PM
mdm350
15
03-16-2010 09:52 PM
jdhudall
19
10-06-2006 06:17 PM
Rbuller24
15
06-11-2003 06:29 PM
