P0713 TFT Sensor Failure/Replacement - Page 2 - Ford Truck Enthusiasts Forums
Old 11-25-2011, 02:32 PM
gfmk gfmk is offline
gfmk is starting off with a positive reputation.
tft sensor changed
Finally got around to changing the sensor and everything is back to normal.Thanks for all the info it made the job sooooooo easy.All the info and pics are priceless.............
Old 05-04-2012, 03:14 PM
David Leone David Leone is offline
David Leone is starting off with a positive reputation.
Magnet
Did you happen to clean off the magnet about the drain plug? Just wondering how much "fuzz" there was. I just finished the job (THANK YOU SO MUCH btw) and was not sure if my accumulation was excessive for 200k or not. Thanks again
Old 05-04-2012, 11:01 PM
Unrealo4's Avatar
Unrealo4 Unrealo4 is offline
Unrealo4 has a very good reputation on FTE.Unrealo4 has a very good reputation on FTE.Unrealo4 has a very good reputation on FTE.Unrealo4 has a very good reputation on FTE.
Mine was fuzzy, not sure how to say how much. But it took alot of wiping to get it clean.
Old 06-07-2012, 12:34 PM
99Exp 99Exp is offline
99Exp is starting off with a positive reputation.
Do you guys know if it is the same on an 03 Expedition?
Thanks,
Kathy
Old 08-26-2012, 11:03 AM
papadelogan's Avatar
papadelogan papadelogan is offline
Snowboard season cometh..
papadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to behold
Quote:
Thanks,
Kathy
Possibly.... and unfortunately that's the best I can give you. I don't know if your Expedition uses the 4R100 or a different transmission. If it's a 4R100 then it is VERY likely the same part. If not... it still could be. Best way to know is to get the part# from your local Ford dealership.
I found this thread because I've had some tranny issues and now the P0713 is the last code I need to sort out. I really don't want to drop the pan, drain, make mess, blah blah but if this turns out to be my fix, then I'll do it gladly. I won't smile though; tranny fluid tastes terrible.
Any chance you still have the Part#?
Old 01-20-2013, 04:06 PM
saharts saharts is offline
saharts is starting off with a positive reputation.
Quote:
Originally Posted by Unrealo4 View Post
Heres my attempt to give back to FTE. Didn't see anything in the tech folder about this. There were some quick posts about it but nothing with shiny pictures.
1. Purchase a new TFT sensor($14.49) and 8-10 Quarts of Mercron LV or SP ($4.49 per quart) at your local Ford Dealership.
2. Drain your old transmisson fluid.
3. Remove your Tranny pan by loosening 20x10MM that are around the edges.
4. Lower the pan and be careful with the gasket it is re-useable.
5. On the passengers side of the valve body in the front you should see the TFT sensor between 2 Solinoids. (See Photo)
6. Disconnect the 2 wire harness and with a pair of needle nose pliers rotate the TFT sensor clockwise with pulling down slightly. FYI Get out of the way or your going to drink some fluid.
7. Install the new sensor by inserting it in the same hole and rotateing counter clockwise. Reconnect 2 wire harness make sure its on the right side where the harness lock is.
8. Clean up the Tranny pan and re-install bolts. Torque bolts to 11Ft lbs.
9. Fill tranny up with Mercron LV or SP. Took me 9 Quarts which is what came out.
10. Check for leaks around the pan and enjoy not having your Trans guage spike.
Sensor location
Old Sensor
I completed this project today, thanks for the step by step instructions. I did notice though that it is counter clockwise to remove and clockwise to install- at least in my 04 Torqueshift it is. The sensor would not come out when I rotated if clockwise. I thought the sensor might break off I was pulling so hard then I tried turning counter clockwise and it easily came out and less that a quarter turn. Thought the correction might help somebody.
Old 01-20-2013, 04:13 PM
Sensor location
Old Sensor
Old 08-22-2013, 09:15 PM
Curt's05's Avatar
Curt's05 Curt's05 is offline
Wiser by FTE
Curt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud of
It was my pleasure to help in whatever way I can.
While I agree the techs that come here to help us all out are awesome. I am not a fan of dealerships either. I would prefer to pay the techs directly if possible. Also the parts department is what gets to me. But I respect the techs here enough to keep my posts free of. Cheezit has been spot on every time.
The tec's are awesome for taking the time to post for us I have had a few of them work on my truck on the weekend, we all need/want extra $$$
Code p0713 Lias 6.0L Power Stroke Diesel 2 09-20-2016 06:04 PM
Trying to help out co-worker - TFT sensor, dealer says need new wiring harness Norton72 6.0L Power Stroke Diesel 3 12-18-2015 09:12 AM
Engine swap - '92 Mustang 5.0HO/AOD into '66 F100 37 Ford guy 1961 - 1966 F-100 & Larger F-Series Trucks 258 10-16-2014 01:39 AM
Replace a TFT Sensor BLADE35 6.0L Power Stroke Diesel 17 10-01-2013 02:18 PM
TFT Sensor??? BigBlue04 6.0L Power Stroke Diesel 14 07-13-2010 01:50 PM
Tags
2000, 2005, 2008, 450, 60, chevy, code, diagnostic, f150, f250, ford, location, p0713, recalls, replacement, sale, sensor, tft
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
