My 1967 F250- Not 56k Safe
Old 03-09-2011, 10:25 PM
PDXHutch's Avatar
PDXHutch
PDXHutch is offline
Howdy, I'm Jeremy. I got this truck about a month ago now, and found you folks while looking for some information. blah blah blah.
Interesting stuff time!
1967
352
4x2
Replaced the following;
Air filter
Carburetor Spacer Gasket
Intake, Head, Valve, exhaust, and Thermostat Gaskets
Water Pump
Starter
Radiator Hoses
Plugs
Plug wires
Distributor Cap
Coil
Battery
Voltage regulator
Alternator
Belts
A push rod
Exhaust Manifold bolts
Various bits and pieces.
I've sandblasted and resprayed the following
Valve covers
Intake manifold
Air Cleaner
Exhaust manifolds
Hangers for the alternator
And now for some classic truck ****!
Old 03-10-2011, 01:07 PM
Mike G's Avatar
Mike G
Mike G is offline
Welcome aboard!
Old 03-11-2011, 06:45 AM
Danger_Dave's Avatar
Danger_Dave
Danger_Dave is offline
whoa thats fricken sweet dude.
you really went through that truck, i bet she purrs.
i have realized over the years if u take care of your f100 it will take care of you.
i drove mine across the country several times and she has never let me down.
i may go through a few daily drivers but one things for sure is the f100 will always be a dependable vehicle that will be there for me,
Old 03-12-2011, 06:04 PM
Lvcrprts's Avatar
Lvcrprts
Lvcrprts is offline
Woo hoo, ain't nothing like looking at truck **** to make a man smile
Old 03-13-2011, 11:50 PM
PDXHutch's Avatar
PDXHutch
PDXHutch is offline
Exactly Very soon I'll have the exaust in and everything running. I'm tight on budget so paint is a bit of a issue, I can rent a paint booth and DYI for around 800 or I can get a Maaco shake your tummy and barf on it jobbie for 300. Either way, its a damn pretty truck.
Old 03-22-2011, 06:56 PM
PDXHutch's Avatar
PDXHutch
PDXHutch is offline
Well the new wiring harness is in place, I've removed that electric ignition and have put everything together. Next up, discover why it won't start and why its backfiring through the carb.
Old 03-23-2011, 02:49 PM
oughtsix's Avatar
oughtsix
oughtsix is offline
Timing? Plug wires in the wrong order?
Nice job on the cleanup!!!!
Old 03-23-2011, 05:29 PM
PDXHutch's Avatar
PDXHutch
PDXHutch is offline
Its the timing, and its confusing the **** out of me lol. I've never adjusted timing before. My understanding is as follows.
rotate to 10 degreees btdc, and set the rotor underneath the number one plug wire. All it gets me is a 3 foot flame out the back
Any kind soul got some advice?
Old 03-23-2011, 09:54 PM
orich's Avatar
orich
orich is offline
Hmm sound like you didn't put #1 piston at tdc. Remove #1 spark plug and if you don't have a remote starter jumper when a helper would be handy. Place your thumb over the #1 plug hole so you'll know when the piston is on the compression stroke then stop and maybe use a socket wench to move it to where it lins up. The compression will blow your finger off the hole as it's coming & passing tdc. Well when all lined up the crank pulley will be lined with timing pointer. I sound like your 180* off or your wires our. Most have to move the dissy back and fourth to get them running b4 setup the time right..
my 2cents
orich
Old 03-25-2011, 05:45 PM
PDXHutch's Avatar
PDXHutch
PDXHutch is offline
I proudly present, Eugene- first start 352FE after upper rebuild.
YouTube - its alive
Old 03-25-2011, 05:58 PM
zenmaster's Avatar
zenmaster
zenmaster is offline
PDXHutch,
Glad to see you have it running.
Did you ever figure out the original no-start problem? What was it?
Cheers,
John
Old 03-25-2011, 06:08 PM
PDXHutch's Avatar
PDXHutch
PDXHutch is offline
Originally Posted by zenmaster
PDXHutch,
Cheers,
John
A few diffrent things,( Before I confess how much of an idiot I am please understand, I've never taken an engine this far apart, and never seen a engine this old before. All of this is completely new to me.) First and foremost was a intermittent short caused by me not screwing the condenser down, and it bounding around as then engine turned causing some spark/no spark. After I removed the electronic ignition I wired in the points and condenser, but lacked screws.
Old 03-26-2011, 10:56 PM
orich's Avatar
orich
orich is offline
Well~~~ you haven't done any thing that we'd all done at one time or another leaving something a little loose. Mostly being side tracked and forgetting to tighten it later. Yup I've learned over the yrs the first thing to trouble shooting is look and check for any loose stuff. Plug any cracked split vacuum hose end. An so on. Well some time we have to back track to find the problem. Well Great you got it going and did it yourself and didn't give up..
until running..
orich
