How do I find out what transmission I have? - Ford Truck Enthusiasts Forums
Old 03-09-2011, 06:04 PM
85fordf150blue 85fordf150blue is offline
85fordf150blue is starting off with a positive reputation.
I have a 1985 F-150. The transmission code on the door is 'W', but I cannot find anything to tell me what that means. Anyone know how to find out? I went to Ford's VIN breakdown website, but of course it says nothing about the transmission.
Old 03-09-2011, 07:03 PM
Galendor's Avatar
Galendor Galendor is offline
Galendor has a good reputation on FTE.Galendor has a good reputation on FTE.Galendor has a good reputation on FTE.
Found this online - I can't vouch for it but it *looks* right. Please correct (and moderator remove) if incorrect.
B (1976-78)- Warner T-85 3speed
C- Ford-Manual 3speed
D- Warner T-89 3speed
E- Warner T-87 3speed
F- Warner T-18 4speed
A (1976-86)- New Process 435 4speed
P- Warner T-19 4speed
B (1979-86)- Clark 4speed O.D.
G- Automatic C4
W- Automatic C5
P- Automatic C6 thru 1977
K- Automatic C6 1978-86
J- Automatic FMX
T- Automatic Overdrive
Old 03-09-2011, 07:55 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
I have no idea if the years in that table are correct, but everything matches up to my 1981
factory shop manual EXCEPT for J which the book says is a C4 available in the F100 and
F150.
Old 03-10-2011, 09:16 AM
I found an article online that shows how to determine what transmission you have.
1. - If the drain pan has 13 bolts its a C3
2. - If the drain pan has 11 bolts and the bell housing is 6 1/4" its a C4
3. - If the drain pan has 11 bolts and the bell housing is 7" its a C5
Going by this I have a C5. Going by the previous chart I have a C4. I don't know what I have.
Old 03-10-2011, 09:56 AM
ctubutis's Avatar
Quote:
Welcome to the Internet, where anybody can post pretty much anything and it's up to the
reader to decide if the source is authoritative & credible or not.
I do what I can to try and keep the information here as accurate as possible (especially
the more important stuff (that which concerns laws)) but it only makes sense to do some
of the time. What you have here are pretty much a bunch of guys hangin' out together at
the local drag strip (or whatever) - you'll get a bunch of opinions but only some of it can
be verified to be true fact.
On that note, here's a picture we use that AFAIK is accurate (I think one of the other
moderators here created it) but I can't guarantee it and wouldn't bet my life on it. IMHO
the best way to know for certain is to use factory shop manuals specific to your year.
Old 03-10-2011, 12:15 PM
Galendor's Avatar
In your first post you said your transmission code on the door was "W". According to the chart, "W" = C5. So if both your drain pain shape and the code indicate C5, I don't see a discrepancy here.
Old 03-10-2011, 01:03 PM
Quote:
You're right the list you posted shows C5 also. I had another list I found from a website that indicated C4 and confused them.
I have the drain pan in front of my now and am I am comparing it to the image ctubutis uploaded. It looks almost exactly light the C4 picture, but has a slight difference. The bolt pattern is the same, but that little extra section at the bottom right is on a different side for me.
Old 03-10-2011, 06:33 PM
ctubutis's Avatar
I should also mention that my 1981 book doesn't have any mention of a code W or of a C5.
Old 03-10-2011, 07:56 PM
ri_truck_guy's Avatar
ri_truck_guy ri_truck_guy is offline
ri_truck_guy has a great reputation on FTE.ri_truck_guy has a great reputation on FTE.ri_truck_guy has a great reputation on FTE.ri_truck_guy has a great reputation on FTE.
I thought the C5 was an 82 or 83 introduction....basically a modified C4.
Old 03-10-2011, 08:09 PM
ctubutis's Avatar
I have no idea, I've owned only two vehicles with automatic transmissions my entire life.
Old 03-10-2011, 08:13 PM
Ironically, my current truck is an automatic, and my car has a Tremec 6 speed....
help transmission went out greenmachine86 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 02-15-2017 11:30 PM
f150 and expedition transmission interchange? Country705 1997 - 2003 F150 1 10-13-2012 09:13 AM
*HELP* 1998 F-150 4x4 4.6 v8 Transmission Question!!! TheNewGuy98 1997 - 2003 F150 7 11-15-2011 12:05 AM
Granny gear transmissions mallard8767 1967 - 1972 F-100 & Larger F-Series Trucks 6 11-19-2004 07:32 PM
transmission fluid bjoern Oil & Lubrication 4 01-07-2002 01:01 PM
Tags
1986, 87, c4, c5, codes, decoder, determine, f150, find, ford, fordvinbreakdowncom, trans, transmission, truck, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
