core support queestion...gas to diesel? - Page 2 - Ford Truck Enthusiasts Forums
Old 03-12-2011, 07:20 PM
helifixer's Avatar
helifixer helifixer is offline
helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.
Quote:
Originally Posted by rumblestrip View Post
Have been in search of one myself. Partstrain and LMC list ones for diesels but not for a/c???
lmc's support only fits up to '95.5 which you could use but you would have to get a radiator and over flow tank and set it up like a '95
Old 05-09-2014, 04:22 PM
ranch-verteran ranch-verteran is offline
ranch-verteran is starting off with a positive reputation.
core suport.
i have a 96 f250 and its got a 460 in it. i need to get a new core support and trying to see if a diesel would work better. i have several problems with the gas core support. i put a 4 core radiator to help with cooling and it helps but doesn't really fit. i plan on cutting both ends off and raising them 3 inches to match the body lift also. the core support i have is bent but i can straiten and cut the bend out. i just not sure if it would be easier to start with a diesel core support and have less work. i know the body lines are all the same.
1994.5 f250 7.3 core support???? Kyle_94obs 1994.5 - 1997 7.3L Power Stroke Diesel 2 08-17-2016 09:52 AM
Radiator Core Support kyle j 1994.5 - 1997 7.3L Power Stroke Diesel 36 05-21-2015 06:01 PM
89 core support davistr 1978 - 1996 Big Bronco 2 01-03-2015 11:20 PM
92-97 F350 Superduty cooling core support fit 84-86 F350 diesel kjgibson2 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 05-16-2012 08:18 AM
77 F250 Radiator Core support removal? eddiey 1973 - 1979 F-100 & Larger F-Series Trucks 8 04-21-2009 01:05 AM
Tags
1996, 1997, 73, 97, core, diesel, f150, f250, f350, find, ford, fors, gas, support, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
