2001 F-150 vibration - Ford Truck Enthusiasts Forums
Old 03-09-2011, 04:39 PM
big-papa big-papa is offline
big-papa is starting off with a positive reputation.
I have a problem with what feels like vibration to me and the people who ride in my truck.The question is i have no vibration at all from a stand still and acceleration but when I turn the vibration is there and only getting worse.It feels like it is coming from the rear of the truck but i could be wrong.So if you had this problem or know whats wrong i would appreciate any and all help. Thanks in advance
Richard
Old 03-09-2011, 05:41 PM
Scalemandave's Avatar
Scalemandave Scalemandave is offline
Scalemandave is starting off with a positive reputation.
If You have a Posi Rear & it does it on a turn from a start it sounds like the clutch pack grabbing in the rear. May just need gear oil changed & posi additive or could be clutch is bad. Just had mine done.
Old 03-09-2011, 06:15 PM
not sure what clutch pack you mean is it the one in the trans or is there one in the rear end?
Old 03-09-2011, 06:23 PM
If It's A studder in the rear when You make a hard turn,& it's a posi, it's the clutches in the rear. The posi additive availabe at autobone or pepboys may help. Like 6 bucks. Check the Vin sticker on the door jam for the code to see what rear you have.
Old 03-09-2011, 07:28 PM
this is what i got from the door tag if it helps or not B6 — 3.73 limited slip (F-150, F-250)
Old 03-09-2011, 07:30 PM
B6 — 3.73 limited slip (F-150, F-250) hope that helps so im guessing i do not have posi.
Old 03-09-2011, 10:30 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
FORDis not positrack... FORD is called limited slip or LS.. yes you have that. What you need to do is go to Auto Zone and get a 7 oz tube of friction modifier for gear lube. Crawl under the truck and take the 3/8 inch pipe plug out of the axle pumpkin just above the drive sahft center line on the drivers side. Put a hooked wire into the hole and see if the level is down 1/2 inch. IF so, just squirt in the addative. If not, suck oout 7 oz of oil with a tube and add the addative. Drive for 50 miles and you should be o.k. after that.
Old 03-09-2011, 11:17 PM
ok i will try that and i'll let you know if it helps
Weird vibration rlreed 1997 - 2003 F150 3 03-10-2011 02:56 PM
vibration under load 901 1968-2013 Full Size Vans 24 06-15-2008 04:55 PM
Vibration mystery solved: Read fanfare 2004 - 2008 F150 42 10-25-2004 06:44 PM
Vibration and Drive Shaft angles? grcutter Excursion - King of SUVs 33 07-28-2004 12:31 PM
Vibration and Drive Shaft angle? grcutter 1999 to 2016 Super Duty 7 07-15-2004 06:36 PM
Tags
2001, clutch, f150, ford, fx4, noise, pack, posi, rear, shaking, stand, truck, turning, vibration, vibrations
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
