Dual Stabilizers
Old 03-09-2011, 11:53 AM
Rudiak's Avatar
Rudiak
Rudiak is offline
Dual Stabilizers
I installed Rancho dual steering stabilizers on my 92 f150. Now when I turn the steering wheel it's making the whining noise. Usually it would only make that noise when I would take it all the way to the stops which I would try not to do. Are the stabilizers putting too much stress on the pump? They are supposed to be universal for f-150 or f-250 and came with different size u-bolts and instructions for both. I followed the installation instructions and used the correct parts. Anyone have any experience, ideas, or thoughts? Thanks.
Old 03-09-2011, 05:56 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Sounds as though they are the straw that broke the camels back.
It sounds w the added stress of the tires and the dual stabalizers, you pump is against the pressure relief
FYI you dont need steering stabalizers
Old 03-09-2011, 06:58 PM
StumpPullerF1's Avatar
StumpPullerF1
StumpPullerF1 is offline
They help with the i beams trucks i heard. Since they like to snake down the road. I was about to get one for my truck, a single though.
Old 03-09-2011, 07:01 PM
Diesel_Brad
Never had one on any of my ford trucks and i have run as large as a 37" tire. And never had any issues.
If you think you need a stabalizer, you need to look at something else, they are just a band aid
Old 03-09-2011, 07:03 PM
Rudiak's Avatar
Rudiak
Rudiak is offline
It steers fine and has lost that floaty feel from the bigger tires. It feels better like you have more positive control. It was a pre-emptive strike for death wobble. I got the duals because the price was not much more than the single.
Old 03-09-2011, 07:32 PM
planehunter's Avatar
planehunter
planehunter is offline
Did you check to see that the stabilizers don't bottom out before you run out of turning room?
Old 03-09-2011, 07:44 PM
Rudiak's Avatar
Rudiak
Rudiak is offline
Yes I checked. I set them at what the instructions said (4.5 inches I think and then torqued down the u-bolts. I ran them from stop to stop basically until my tires hit the radius arms. Tires are 32x11.50R LT.
Old 03-09-2011, 09:18 PM
Sbrown's Avatar
Sbrown
Sbrown is offline
Take one off and see if it still does it?
Old 03-09-2011, 10:46 PM
Restoman2's Avatar
Restoman2
Restoman2 is offline
Your adding a ton of stress to your steering gear. I would look at balance issues. Look into Equal.
Old 03-10-2011, 03:31 AM
hav24wheel's Avatar
hav24wheel
hav24wheel is offline
Originally Posted by Restoman2
Look into Equal.
If you use that stuff, spin the tire on a balancer first, and add however much wt the balancer says it needs. I've gone by the charts you can find everywhere with poor results.
