97' F250 DIED WHILE DRIVING - Ford Truck Enthusiasts Forums
Old 03-09-2011, 10:19 AM
cbhd55 cbhd55 is offline
cbhd55 is starting off with a positive reputation.
While driving truck died, like shutting the key off. I changed the fuel filter and CPS. I then found this site, after reading a few threads, I performed a few tests. There is no WTS light when the ignition is turned on. There is no CEL when ignition is turned on. There is no smoke coming out of tailpipe when cranking over. Any help would greatly be appreciated. Thank you in advance.
Old 03-09-2011, 10:24 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
First of all, welcome to the site! Sorry to hear you're having trouble.
First thing to check would be fuse #22. It runs your PCM (Powertrain Control Module - aka engine computer). Unfortunately it also runs the fuel bowl heater element which is known to short out and blow the fuse, thus killing the power to pretty much everything that makes the engine run. Check that fuse carefully (with a meter if possible) and we can go from there. By the way, if it is the fuse, you might want to consider unhooking the fuel bowl heater to prevent it from happening again. Lots of us on here run all year round without the heater, so it's not really a concern.
Good luck, hope this helps.
Old 03-09-2011, 10:27 AM
Oh, by the way, fuse 22 is a Maxi fuse located under the hood and not in the fuse block in the cab. Sorry, should have said that before.
Old 03-09-2011, 10:40 AM
Copedawg's Avatar
Copedawg Copedawg is offline
Copedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant future
WELCOME TO FTE!!!
Here are some sites you should add to your favorites:
1994.5 - 1997 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums
http://pages.prodigy.net/stevebaz/_i...az/index3.html
1996 Bronco/F-Series Workshop Manual
97-15A 7.3L DI Turbo Workshop Manual
Listen to Nate...He has you covered!
22 fuse. I would even throw it away and replace it.
Welcome aboard!
Old 03-09-2011, 12:42 PM
Fuse #22 was blown. how do I disconnect the fuel bowl heater? I see the two connections on the driver side of the fuel filter housing.
Old 03-09-2011, 12:46 PM
Copedawg's Avatar
Unplug it BEFORE you replace the fuse.
Old 03-09-2011, 12:56 PM
Thank you for excellent pic. Does the fitting pull off?
Old 03-09-2011, 01:02 PM
Copedawg's Avatar
yes sir! Just yank it off....
Let us know when it is running or if you have any other questions if you get stuck.
This is a free 24/7 technical help site it seems so stick around. All these people around here were once green like you with 1 post looking for help and now they are experts. You are next.
Old 03-09-2011, 01:19 PM
THIS IS A GREAT SITE, WITH EXCELLENT HELP!!!! I will make sure to let you know how it all goes. I cannot thank you all enough!
Old 03-09-2011, 01:26 PM
Copedawg's Avatar
Hurry back!
Old 03-09-2011, 01:28 PM
Yeah, be sure and let us know how things turn out.
Old 03-09-2011, 01:34 PM
BuckHammer's Avatar
BuckHammer BuckHammer is offline
BuckHammer has a good reputation on FTE.BuckHammer has a good reputation on FTE.BuckHammer has a good reputation on FTE.
If that turns out to be the ticket, this thread has to have set some sort of record for fastest problem/solution set ever resolved. Only five minutes between the original post and first response.
Old 03-09-2011, 01:37 PM
Copedawg's Avatar
Quote:
That is what seperates 7.3L OBS forum from the rest!
Old 03-09-2011, 02:29 PM
RÖENTGEEP's Avatar
RÖENTGEEP RÖENTGEEP is offline
FOREIGN GURU
RÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to behold
Wink
Quote:
Another welcome.
here is a pic of the connector (the spade type)
Old 03-09-2011, 02:35 PM
Up and running, replaced the #22 fuse after unplugging the bowl heater element. Thank you, for all the help. This is a great site with excellent help. Greatly appreciate all the help.
1989 F250 8CYL. No Start. Engine died while driving Anthony Bauwens 1987 - 1996 F150 & Larger F-Series Trucks 3 08-05-2016 10:00 PM
1972 F-250 will not shut off with key? Donnalee 1967 - 1972 F-100 & Larger F-Series Trucks 7 06-15-2016 08:02 PM
Truck Starts and then Dies - Fuel Pump? Jjk27 6.0L Power Stroke Diesel 18 07-09-2015 03:38 PM
Engine stalls when shifting into gear rogerhinson 1978 - 1996 Big Bronco 2 03-20-2011 01:22 PM
Battery keeps going dead. zoomer 1967 - 1972 F-100 & Larger F-Series Trucks 1 03-25-2009 03:19 PM
Tags
1997, 73, 75, 96, 97, 97expeditiondiedwhiledriving, died, dies, diesel, driveing, driving, expedition, f150, f250, ford
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
