Stock ford coil volts - Ford Truck Enthusiasts Forums
Old 03-09-2011, 08:20 AM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD BURNSTOUGHFORD is offline
BURNSTOUGHFORD has a good reputation on FTE.BURNSTOUGHFORD has a good reputation on FTE.
How many volts are they?
Im looking at gapping my plugs farther, and see some of the aftermarket ones are 48-49k volts.
Im hoping to get to .055 on the gap. And i see that the sixlitre tune up requires a aftermarket coil.
I have heard the OEM coil is plenty strong and was wondering if it would push a .055 gap without issue.
Old 03-09-2011, 09:07 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
The OEM coil is plenty strong and would push a .055 gap.
But it is the plug wires that you have to think about. The higher the voltage the more likely it will cross-fire.
Old 03-09-2011, 09:58 AM
Thanks, what is the voltage of the OEM coil?
Old 03-09-2011, 10:35 AM
subford's Avatar
As much as 40K volts.
Old 04-08-2011, 09:03 AM
dhonnoll dhonnoll is offline
dhonnoll is starting off with a positive reputation.
OK so I put it in. Works great! Now MSD's web site wants to sell me an adapter in order to go with the 5527 as opposed to the 8227. Harness, MSD 6 to Ford TFI - 8874
but I don't find that harness necessary. The connector I have fits in the 5527 just fine. It doesn't take up all of the space of the slot, but the forks line up and connect fine, the clip even clips on there fine. And as you can see by the one they sell it has no clips. So, I'll save the $10 for the price of the connector plus shipping and the $14 in over inflation of asking price of connector, plus the $xx.xx in what they are asking for shipping on top of that.
surprising spark plug find F-250 restorer Ford Inline Six, 200, 250, 4.9L / 300 3 07-28-2013 10:10 PM
Need a Distributor - Unable to Cross-ref the Part Number ChristopherBarnette 1987 - 1996 F150 & Larger F-Series Trucks 11 07-13-2012 08:07 PM
What would cause multiple coils to fail? Fordenthusiasts 1987 - 1996 F150 & Larger F-Series Trucks 16 06-21-2012 06:23 PM
Tune up, now wont start. Redcoat 1987 - 1996 F150 & Larger F-Series Trucks 6 02-28-2010 06:09 PM
My Bronco out scored my Honda on emissions! Bull 1978 - 1996 Big Bronco 4 02-28-2002 09:09 PM
Tags
352m, 54l, 78, 88, bronco, coil, f100, flat, ford, head, output, starting, stock, svoltage, voltage, volts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
