runs rough, no power
I disconnected (unplugged) the EGR, which made it cold blooded and turned on the Check Engine Light. Got tired of the problems it caused, so I plugged it back in - but it is still runs like it did when it was unplugged, rough and no power till it warms up, along with blue smoke. It does not have to be very cold to do this, 45-50 degrees is cold enough. If I plug in the engine block heater then all is great. Is there something that was un-programed when I unpluged the EGR - or needs to be re-programed when I plugged it back in? Thanks for any help - Dale
Sounds like injector stiction. You might consider running some Rev-X see if that clears it up.
Thanks for the replies. No I do not have a way to pull codes. My son-in-law as told by a Ford mechanic that I should disconnect the batteries for 30 minutes, then start it up and let it idle for 45 minutes. This would re-progam the fuel and air to the correct settings?
Anyone know if this could be a fix? Thanks - Dale
Received 5,131 Likes
on
Autozone (if one close to you) can check codes for free also. Advance auto can also but depends on counter guy if they want to. But hate to change thread subject...but I changed my oil other day and seems truck runs lil rougher also than before changed oil. Used rotella 15w40. Any thoughts?
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
01-16-2017 05:04 PM
Prozon
13
01-11-2016 01:44 AM
