Death wobble mystery
I have a knock I hear from the front driver side going over bumps. I can't for the life of me figure out where it's coming from. Ball joints, shocks, outer tie rod ends, all replaced within last 8 months. Just replaced the idler arm today and it wasnt the problem. Other than the inner tie rods (going to go ahead and do that tomorrow, originals have 197K miles, as well as check the shock) is there anything I'm forgetting. Yes, I've resorted to throwing parts at a problem. Damn you death wobble.....
Thanks ahead for any suggestions.
Actually it sounds like the pitman arm. It's easy to miss this when the truck is jacked up, and all the linkage is hanging on that joint. Try a pc. of wood under the linkage, next to the arm, and pry it up a bit. Any movement at all, change the pitman arm.
I did mine 3 years ago, same exact problem.
Dave
Dave
Death Wobble
Mine made a knocking noise for quite some time. It was the roters needing to be changed. The break assembly was making an extremely loud clanking noise, but that was the break assembly trying to grab on to a severely small roter cylinder. Hope this makes sense. Hope it's easy to fix.
My '99 F-150, 4.6 has had ALL of the above suspension ills at one time or another. Without being able to hear the knocking, it's hard to tell in an online type situation. However, ball joints & the pitman arm tend to have deep and fairly loud knocks, tie rod ends & idler arms fairly loud but higher pitched knocking ( as well as tire wearing), stabilizer links sound similar to the tie rods, but almost a rattling knock.
If you are checking around again, look at the shock bushings around the top mount. I have replaced several sets for myself and others that seemed to have rubber bushings that were too thin ? The top retaining nuts ran out of thread on the shaft before the bushings were compressed ( knocks every time.) This one is easier to find because the knock is higher pitched and comes from higher up in the front end than the rest.
Dave
Dave
JoeGrinder
1999 to 2016 Super Duty
20
12-10-2015 10:04 PM
cowgirlup11
21
04-23-2011 01:22 PM
cadunkle
17
01-23-2009 03:58 PM
