Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 03-08-2011, 10:23 PM
Philip Berardi's Avatar
Philip Berardi Philip Berardi is offline
2000 Ford F-250
Philip Berardi has a very good reputation on FTE.Philip Berardi has a very good reputation on FTE.Philip Berardi has a very good reputation on FTE.Philip Berardi has a very good reputation on FTE.
First batch with biodiesel
Just wanted to make sure i am on the right track here.
i am making a 17.5 gal batch. it is my first batch.
i let the methoxide and oil mix for about 1.5 hours. finshed circulating at 9:30pm. Should i take a sample off the top tomorrow around 10am and do a 3/27 test to see if i can drain the glycerin and continue to the wash?
Thanks guys!!
__________________
Philip Berardi - 2012 F250 Lariat CC SB FX4 - Weather Tech Floor Mats / AVS Vent-Visor / H&S (on the closet shelf until 35k )/DRL/Switch Back Mod
  #2 (permalink)
Old 03-08-2011, 11:14 PM
binuya's Avatar
binuya binuya is offline
Garage is empty, add now
binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.
Thanks guys!!
First off, what was your processing temperature and titration #, (BTW, Naoh or KOH?).
Usually, 3/27 is taken at the when you think it is close, but do not shut down processor yet. Pull a sample, let it settle (5-10 minutes), take your 3 ml of settled bio and shake with 27 ml of methanol. After 15-20 minutes, it should be clear with no droplets in the bottom. Very important that the 3/27 be performed at 68F. Any warmer will give a false pass, and any cooler will give a false fail.
After you pass 3/27, then shut down processor. For me, my processing temperature starts at 140F, usually pass 3/27 in 1 hour 15 minutes, processor is shut down at about 1.5 hours run time, settle 1 hour, drain glycerol, proceeed to wash.(I use KOH)
__________________
2001 F250 7.3 CC SB 4x4 Lariat
S&B Intake, MBRP 4" Turbo Back, HPX, AIH Delete, Hutch and Harpoon,
Isspro EV2's, Bilsteins, Warn Premium Hubs, Firestone Bags with Airlift onboard, Fumoto,
Homebrew American Biodiesel (B100 whenever I can)
1995 Mercedes Benz E300D, 2004 Mercedes ML350
  #3 (permalink)
Old 03-09-2011, 08:59 AM
2000 Ford F-250
alvin so you keep heat on it and keep it circulating even after you heat the water up? here is what i had
Titration - 4ml
Temperature outside 40F
KOh
Let me summerize what you did real quick to see if i understand -
1. Titration
2. Heat oil to 130F (circulating Pump on)
3. Mix Meth and KOh (circulating pump on)
4. Keep heat and circulation on the entire time
5. Test 3/27 after 1.25 hours
6. If pass let pump run 15 more min and then turn off heat and pump and let everything settle for one hour and drain glycerol
7. wash
This being said...if you pass the test and then go to drain the glycerol...how do you know you have all the glycerol out?
__________________
  #4 (permalink)
Old 03-09-2011, 09:35 AM
binuya's Avatar
Titration - 4ml
KOh
1. Titration
7. wash
#4. Do not keep heat on. Explosion hazard. If you are at 130F when you are metering in the methoxide, you should be fine. I usually go to 140F, shut down heat, then meter in the methoxide.
#6. The reason I usually go to 1.5 hours is because I test 3/27 at 1.25 hours, but keep the processor pump running while I wait for the sample to settle for the 3/27 test.
You will know when you drain most of the glycerol out. Glycerol looks like syrupy coffee. It will quickly change to golden biodiesel. At your titration level, figure on glycerin quantitiy being about the same volume as your methanol input (4.25 gallons or so?). You will never get every speck of it out, and assuming you will water wash, I suggest your first wash cycle to be a static wash. Meaning, after transferring your bio to wash tank, slowly pour a few gallons of warm water into it, let settle 30 minutes to an hour, and drain. Wouldn't hurt to repeat, then proceed to what ever your normal wash routine would be. Keep in mind, slow, easy, and gentle for the first few washes to avoid creating an emulsion. Warm water is best, I wash at 100F-120F.
BTW Phil, what type of processor and wash system do you have? Good luck with this, and let us know how you are progressing. If you run into problems washing, I've run into enough problems to know how to get out of them.
__________________
  #5 (permalink)
Old 03-09-2011, 09:55 AM
2000 Ford F-250
thanks brotha good info right there.
i did the 3/27 test and it came back with no floating oil at all. good sign!
i will post pics of my setup in a min or two, i just transfered to the wash tank. going to go get some hot water and wash it up without bubble rock first then i guiess ill do the bubble rock...17.5 gall of oil, im going to do 5 gal of hot water.
__________________
  #6 (permalink)
Old 03-09-2011, 10:22 AM
binuya's Avatar
On the 3/27, an under reacted batch will show at the bottom. Usually as a bead of oil.
When you are doing your wash, for the first few cycles, it will be opaque looking, like orange juice. This is normal. Just keep washing, settling,and changing out the water until it begins to darken and clear up. At this point your about 1/2 way through your wash cycles.
Good luck and looking forward to your processor pics.
__________________
  #7 (permalink)
Old 03-09-2011, 10:16 PM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
Sounds like your on the right track to going bio. Only tried water wash once, got an emulsion. Don and others persuaded me to go with Magnesol Dry wash and never went back...
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #8 (permalink)
Old 03-10-2011, 12:11 AM
2000 Ford F-250
please elaborate on the magnesol..where do i get it. its weird i was actually reading an article on it. a step by step would be nice.
got back from meeting tonight and the bio was bubbelin away in the still, has a real real dark amber color..hope thats ok.
__________________
  #9 (permalink)
Old 03-10-2011, 12:29 AM
2000 Ford F-250
alright picture time -
  • Picture of the stills, far right is primary, left one is wash. blue drum is for completed fuel, going to switch to plastic to help lessen condensation.
[IMG]Click the image to open in full size.[/IMG]
  • Chemical shelf..still needs organizing.
  • was tired of moving the 55 gal drum around so i quick built this dolly...works great
  • first 3/27 with first batch....
If anyone could teach me a little about how to use the dry wash that would be great!!
__________________
  #10 (permalink)
Old 03-10-2011, 10:33 AM
binuya's Avatar
Good looking set up there Phil. And yes, your wash sounds like it's going well. I see that you are looking into drywashing too. I will be doing that as well in the near future when I complete my new reactor. Just a quick heads up though. Master your processing first. I have seen more than a couple people jump into drywashing before mastering proper processing only to have fuel related vehicle issues. But you seem to be headed in the
right direction. Best of luck, and keep us posted.
__________________
  #11 (permalink)
Old 03-10-2011, 10:56 AM
2000 Ford F-250
thanks! took out the water today just makes me nervous until i see that little bit come through the tube and i quick shut off the drain vaulve. keeps looking beter and better tho. thanks for the tips.
__________________
  #12 (permalink)
Old 03-10-2011, 11:30 AM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Quote:
After making bio for 7 years I've NEVER met anyone that tried Magnesol and went back to water wash.........not one........
If you do a forum search for Magnesol you'll get PAGES of results.
Here are a few:
http://www.ford-trucks.com/forums/75...sh-my-bio.html
http://www.ford-trucks.com/forums/55...w-me-more.html
http://www.ford-trucks.com/forums/58...d-filters.html
http://www.ford-trucks.com/forums/62...-your-bio.html
Lot's of info in this forum....................
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #13 (permalink)
Old 03-10-2011, 12:44 PM
2000 Ford F-250
lol thanks don, i ignored my first responsibility to search first. sorry! thanks for the links
__________________
  #14 (permalink)
Old 03-10-2011, 12:49 PM
1935 Ford pickup
No problem at all Phil. We're all here to help each other out!
__________________
  #15 (permalink)
Old 03-10-2011, 04:49 PM
Rushmore X's Avatar
2003 Ford Excursion
That's one thing that's been nice with this forum, lot's of people willing to help others out with GOOD information...
__________________
Tags
1966, 67, b100, ford, plymouth, propane, run
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
