95 f250 HARD shifting problem - Ford Truck Enthusiasts Forums
Old 03-08-2011, 11:07 PM
jonc123 jonc123 is offline
jonc123 is starting off with a positive reputation.
hey all, I have a 1995 f250 7.5L 460. This thing shifts very hard from 1-2 and into R. I had the tranny rebuilt from a transmission shop and it still shifts very hard. Brought it back and they cant figure it out. they say that is just how it is.
Is there anything else it could be like a tranny module or something?
Any help would be appriciated.
Thanks
Jon
Old 03-09-2011, 08:27 AM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
The transmission is 100% electronic controlled, it would be my best suggestion to check for codes. Many times there can be a problem without having a Check Engine Light. Warm up the engine and transmission then do this: Ford Fuel Injection How To Run a Self-Test or purchase one of these: Equus 3145.
Old 03-09-2011, 11:22 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
You have a sensor problem... pull the codes.
Old 03-11-2011, 07:36 PM
Quote:
I just ran the codes twice and nothing, any other ideas?
would a speed sensor come up in the codes or transmission module?
Thanks
Old 03-11-2011, 07:52 PM
rla2005's Avatar
Define nothing....At the very least you should get the 111/111 System Pass code.
The engine and transmission are both controlled by the PCM....Powertrain Control Module aka ECM aka EEC-IV
Old 03-11-2011, 08:11 PM
Yes I got the 111 code. both with vehicle on and off.
Old 03-11-2011, 08:32 PM
rla2005's Avatar
It is possible to have a TPS or VSS problem without triggering a code. You can test the TPS output with a meter to see if there are dips/ripples in the output signal. The VSS is a little tougher without an oscilloscope.
Use this as a reference for the TPS: Ford Fuel Injection Throttle Position Sensor (TPS)
Many times when the VSS has a problem it will trigger a code, but for you that is not the case. If the TPS appears okay, then I would suggest trying a new VSS.
Old 03-11-2011, 08:35 PM
ok thanks so much, im going to look at the TPS, I think i replaced the VSS years ago. Ill report back
Old 03-12-2011, 01:43 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
You may have a bad EPC solenoid or a bad wire (shorted to ground) in the harness going to the solenoid.
Could also be the PCM Computer or as rla2005 said the TPS.
Old 03-22-2011, 04:12 AM
It occured to me that I had to replace the instrument cluster a while back. What happened was that something in the cluster was making the truck sputter like it was running out of gas, i had a ford master tech come look at it and he said it was the cluster. after I got a new cluster from a junkyard it fixed the sputtering problem but tranny was hitting R and 1-2 HARD. If I didnt put a cluster in from the same engine and tranny would this cause the hard shifting? I got it from a junkyard and dont remember if it was the EXACT same engine etc. as mine
Thanks...
Old 03-22-2011, 07:32 AM
subford's Avatar
I have no idea how something in an instrument cluster would make and engine have a sputtering problem.
You have no out going signals from the instrument cluster other then to turn on the alternator and the speed signal form the PSOM to the PCM.
I do not think your ford master tech knew what he was talking about.
If anyone can explain how an instrument cluster could do this please post in this thread.
On the other hand the PSOM in the instrument cluster can cause hard shifting in the forward gears as if the PCM loses the speed signal the transmission will go to max oil pressure.
I do not think this would have anything to do with "R" however.
Old 03-22-2011, 12:28 PM
Well thats what I thought but when I replaced the cluster it was fixed. however I think I may have gotten one from a 5.8L. When I had this problem the Tac would jump arround out of control and it would sputter, Stall and act like it was running out of gas. The guy came by and disconnected the VSS and it corrected it but the tranny hit hard. He told me I needed a new cluster. I replaced the cluster, reconnected the VSS and it wasnt sputtering anymore, but the tranny still hit hard.
And ya R hits really hard, probably worse than the others.
Old 03-23-2011, 12:34 AM
Hey, where is the epc solenoid and is there a way to test it?
Thanks
Old 03-23-2011, 08:05 AM
subford's Avatar
Quote:
Thanks
Yes, here is the test for its coil:
2008 f250 opportunity freefisherman 1999 to 2016 Super Duty 3 06-11-2015 09:02 AM
Transmission shifting hard jayhawk714 Clutch, Transmission, Differential, Axle & Transfer Case 0 11-17-2014 01:49 PM
C6 auto shifts hard into drive BBpwer 1973 - 1979 F-100 & Larger F-Series Trucks 7 08-07-2014 12:24 AM
99 F250 Shift linkage question Epd444 1999 to 2016 Super Duty 4 04-22-2012 12:02 PM
np435 hard to shift warm 4onfloor Clutch, Transmission, Differential, Axle & Transfer Case 4 05-02-2011 07:41 AM
Tags
1995, 460, 95, 96, 97, 99, erratic, f250, ford, hard, harsh, problems, shift, shifting, shifts, transmission, troubleshooting, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
