Left Side Speakers not working - Ford Truck Enthusiasts Forums
Old 03-08-2011, 09:23 PM
ffjsh ffjsh is offline
ffjsh is starting off with a positive reputation.
Alright i have one here to stump everyone.... My uncle called me and his 05 f150 STX left speakers both front and back arent working. I took a look at it the other day, i switched his radio with my radio from my 06 f150 stx, then i switched my front speaker out. didnt work. I looked at his back speaker and the magnet on the speaker was stuck in the door. I checked fuses and dont see any blown. Any other ideas?
Old 03-09-2011, 12:19 AM
dgndngrngr84's Avatar
dgndngrngr84 dgndngrngr84 is offline
dgndngrngr84 is starting off with a positive reputation.
could be a break or short in the bundle of 4 speaker wires probably between the drivers side door and the radio. Is this on an extended cab or regular cab? I would try to follow the wires back from the speakers to the radio. Possibly leave the radio on so when you get to the break in the wires you'll know where it needs to be fixed. I know you run the risk of blowing the fuse if it shorts out but I guess that's were I would start. I'm sure someone else here has run into something similar and can help you out more. Good luck!
Here are the color coding for the wires from the left speakers to the radio:
left rear + Grey/Light Blue
left rear - Tan/Yellow
left front + Orange/Light Green
left front - Light Blue/White
There is a junction point (C238) before the wires enter the doors down behind the hood release area:
Other than the connections at the speakers and at the back of the radio, C238 is the only other place where all the speaker wires would connect.
97 F150 radio wiring diagram help! BAJACRAZY32 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 0 11-11-2016 08:09 PM
How is stock radio grounded? Mdc9966 1973 - 1979 F-100 & Larger F-Series Trucks 8 12-08-2015 07:23 PM
Speaker/Radio - Issue? great white 2004 - 2008 F150 6 04-24-2010 02:53 PM
Speaker Problems TallPaul Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 15 08-06-2009 08:39 PM
speakers not working.. radio works fine ford_racing_4_life Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 2 11-21-2007 08:54 PM
Tags
2002, 2003, cab, color, extended, f150, ford, forum, front, left, negative, positive, side, speaker, speakers, sport, stopped, trac, wire, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
