Repairing FICM harness connectors
Old 03-08-2011, 08:42 PM
Piolet's Avatar
Piolet
Piolet is offline
Trying to do a bunch of stuff to rule out problems before I may have to face up to an injector (engine knocks, especially when rpms drop as engine goes into 5th gear.)
One FICM connector was broken and tried a zip tie repair. Didn't work.
I found these 3 replacement connectors. Each is $30+/-.
Anybody know which is which? Are they for X1, X2 & X3?
Has anybody done the swap? Looks like it could be a royal pain.
2003-2009 International VT365 FICM Connector part ap0018
2003-2009 International VT365 FICM Connector part ap0019
2003-2009 International VT365 FICM Connector part ap0020
Then I find 3C3Z-9D930-AA for $71.
Is this the whole FICM harness? I can't get a picture.
Is 3C3Z-12B637-BA the whole harness? I see that for $240.
I can't find a good photo or description of these items online and I can't get down to dealer parts dept for a few days.
Old 03-08-2011, 08:57 PM
mrwrench's Avatar
mrwrench
mrwrench is offline
change the harness > ebay $90
Old 03-08-2011, 09:18 PM
High Binder's Avatar
High Binder
High Binder is offline
Which part is broken? It looks like the clip from the male portion is still there.
I've seen a lot of connectors that have turned green from corrosion and lost continuity because of the corrosion, could that be your problem?
Old 03-08-2011, 09:36 PM
Piolet's Avatar
Piolet
Piolet is offline
I really don't know what the problem is. I don't have scan equipment or code reader tool yet ... although tax rebate comes in soon!!
The truck has no CEL and starts fine. Then it shakes at idle. Shake somewhat noticeable when driving. Shake EXTREMELY noticeable when speed is around 45mph and rpm's drop back to 1,100ish ... so I guess it's going into 5th.
Took everything apart again today. All pins were fine and connectors were clean. This was the only thing I could point to.
Rev-X is on its way in the mail as we speak. I hope that may help. Right now the truck is a giant paper weight.
Does a FICM loose it's programing if it sat around disconnected from the vehicle for about 2 weeks in the cold?
Old 03-08-2011, 10:09 PM
iduger's Avatar
iduger
iduger is offline
Go on ebay entire ficm harness 100.00. or try salvage yard found mine 25.00.
Old 03-08-2011, 10:15 PM
m-chan68's Avatar
m-chan68
m-chan68 is offline
3C3Z-9D930-AA is the whole FICM harness, which includes the connectors to all eight injectors, the two main connectors to the FICM (cylinders 1, 4, 6 & 7 and cylinders 2, 3, 5 & 8) and the main FICM ground eyelet on the rearmost intake manifold stud on the driver side.
3C3Z-12B637-BA is the entire engine harness that connects everything together on the engine, which includes the following: A/C compressor clutch switch, the green and black GPCM connectors, the main positive lead to the passenger side battery, the alternator connector as well as the positive terminal, the EOP & EOT, the VGT, IPR & ICP, fan clutch, EGR valve, ECT, EBP (even though it's useless on 2003 engines), IAT #2, the third FICM connector, the middle PCM connector, the two main connectors to the frame harness and last but not least, the CKP & CMP. By the way, for $240 that's cheap.
I hope the text in red is helpful enough.
Old 03-08-2011, 10:35 PM
Piolet's Avatar
Piolet
Piolet is offline
Thank you Sir!!
Huge help!
Old 03-08-2011, 10:40 PM
High Binder
Kinda sounds like an ICP issue with the shaking at speed. Mine did a little jerking around 60-70mph and the new ICP fixed that.
The ficm (unless something else happened) will keep it's program.
Rev-X will help if it's an injector problem but it's just a band-aid. I run it and love it but I know it's just a matter of time before I'm back into it putting in new injectors.
Old 03-08-2011, 10:53 PM
Piolet's Avatar
Piolet
Piolet is offline
Originally Posted by High Binder
Kinda sounds like an ICP issue.
That's what started all this. I just replaced the ICP and connector.
The oil leak's gone and the rpm's have settled down.
Maybe I messed up splicing the connector
Boy that would suck. Hopefully its sunny on Saturday.
Old 03-08-2011, 11:00 PM
High Binder
?Maybe. You mentioned that you don't have a scanner so it's going to be hard to tell. I watch my ICP on my scangauge to make sure it's reading but I don't know if there is a trick to figuring out if it's reading without a scanner???
May be time to get a scangauge and see where it's at. I dunno but your symptoms sound like mine when I had the ICP going out. I got a scanguage off Amazon.com for $200-ish (don't remember exactly) but it was one of the best buys I've ever made for a car.
Old 03-09-2011, 05:30 AM
bismic's Avatar
bismic
bismic is online now
Received 2,458 Likes on 1,701 Posts
I can't recall - I assume your truck is an '03 or early '04?
Old 03-09-2011, 07:41 AM
Piolet's Avatar
Piolet
Piolet is offline
Early '03. ICP at rear of engine.
I'll shameless plug my last overly descriptive post on this ...
https://www.ford-trucks.com/forums/1...placement.html
..... this is the full story.
If an injector(s) didn't just stick or fail over night then I think I must have messed something up I guess. Maybe I was too rough with the harness when I had it pulled back to do the splicing.
This weekend I'm going to splurge on an Edge insight CTS.
I hate posting without being able to supply parameters. Plus it'll finally give me some of the gauges I should be viewing too.
Any help or suggestions appreciated.
Old 03-09-2011, 11:21 AM
rocky1074's Avatar
rocky1074
rocky1074 is offline
Parts guy ed has the FICM Harness 3C3Z-9D930-AA 70.87
www.partsguyed.com
Old 03-11-2011, 10:42 PM
Piolet's Avatar
Piolet
Piolet is offline
Talking Working again!!
Problem solved.
Spent a good hour today online trying to price harnesses, or connectors, looking to get a scan tool, thinking I'd have to get injector(s), trying to figure out how I might pay for it all. Feeling pretty down.
Went outside to redo my work just one more time, just in case, and found the connector on the injector closest to the firewall wasn't on properly
Thankfully the clip was still on it.
Plugged it in and now it runs just fine. ICP done! 3 weeks later!!!
fixxxer-upper
08-02-2019 12:33 PM
WA_PSD
24
03-19-2013 07:36 AM
Piolet
06-25-2012 08:54 PM
dukie1877
11-23-2011 12:46 PM
cheezit
06-24-2010 07:16 PM
Quick Reply: Repairing FICM harness connectors
