My hazard flashers don't work. All turn signals and other lights work, but when I push down the switch for the hazards, I get nothing. Is the switch bad? What else could it be?
Reason: Resolved
The flasher you can see in the fuse panel is for the turn signals the one for the hazards is on the back of the panel. You have to get to it from under the dash.
Okay. I took a look at it today, and found the thing you guys are talking about. It was on the back of the fuse panel. It's a metal cased thing that says Wagner 552 on it, and it bears Motorcraft part number D2AB-13350-AA.
Man you have some long toes! j/k, lol
That looks like a flasher to me. Is that the same flasher as the turn signals? That may even be the same one I don't know on our truck (haven't been there , yet....knock on wood). If you can try to exchange them and see if one is bad.
fuses blow for a reason, too much heat (amperage) make sure you figure out why it blew
-juan
Could it have been caused by leaving the hazards on for a long time? The truck was commercial when I bought it, and it could have been idling with hazards on in the street for a long time.
get an electronic one if you have a lot of trailer lights. I don't remember the part number on mine but both of them are a little bigger, have clear housings and you can see the insides. They say electronic on the side. They made mine all flash normal again regardless of how many lights I have on.
