2003 4.6L Headlights out, Dash lights out, - Ford Truck Enthusiasts Forums
Old 03-08-2011, 07:39 PM
TigOldBitties TigOldBitties is offline
TigOldBitties is starting off with a positive reputation.
Question 2003 4.6L Headlights out, Dash lights out,
Hi all!
I'm having a little electrical problem with my 03' 4.6L SuperCrew
Goes a little like this:
Upon turning on the tuck and switching the headlights to the "on" position, the right one turns on, and and the left one stays off. I then turn the light switch to the "off" position, and the right headlight stays on.
Even when shutting the engine off, and exiting the truck, the right headlight STILL stays on. It's the exact same problem with the high beams (both turn on and stay on) even when I take out the key.
Now, when I hit the "lock" button on the key fob, then all/any lights turn off.
The second problem is the interior dash illumination lights are not working either (Guages, radio, A/C, etc). Both problems started at the exact same time, so I believe they are connected. I was thinking it might be a fuse problem, but I don't know which of fuses control those two operations.
Anyone have any idea what the issue could be?
Thanks in advance and let me know if you need any more info
Edit: I forgot to add a fact that may or may not be important. The truck has after-market headlights that were installed by the previous owner. I am going to charge the battery up tonight just in case and take a look at the ground wires first thing tomorrow.
Anyone have a Chart for the fuse boxes that display what each fuse controls??? Thanks
Old 03-09-2011, 07:12 PM
Update: I fixed every problem minus the left side low-beam headlight. All other problems were solved by replacing a 15 amp(blue) fuse in the engine bay fuse box.
I'm thinking that one bulb is just out.
Old 03-11-2011, 01:52 PM
All fixed. Ended up being The bulb, and two fuses. Thanks everyone for rushing in all at once to help lol.
Old 03-11-2011, 04:29 PM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
KingRanchMan02 is gaining momentum as a positive member of FTE.KingRanchMan02 is gaining momentum as a positive member of FTE.
No problem.
98 e150 instrument lights-Strange Issue rustypierce 1968-2013 Full Size Vans 6 10-27-2016 03:24 PM
Gremlin Turn Signal / Flasher Issues (2000 F350 7.3L) Oldest Ivan 1999 to 2016 Super Duty 4 12-30-2010 06:09 PM
Marker / Tail light problem djjoshuad 1978 - 1996 Big Bronco 2 09-07-2006 02:31 PM
Dash / Marker / Tail light problem - 93 bronco djjoshuad Electrical Systems/Wiring 3 09-04-2006 07:52 AM
1975 F250 Electrical Problem 75F250Colorado 1973 - 1979 F-100 & Larger F-Series Trucks 7 11-11-2002 08:50 PM
Tags
04, 2003, 46l, changing, coming, dash, expedition, f150, ford, headlight, interior, lights, ranger, shut, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
